Visits: 618
Visits: 618
Visits: 618
Progress on the internals. Pistons are cleaned and balanced. The vintage pistons are Jahns, and came from Pete Blakeley. Vintage parts in our vintage gasser. Should be darn near 12:1 compression when done. Nice and crispy. Block pic shows the relief on every cylinder to clear the 2.02" and 1.6" valves when running a .600 lift cam and rocker combo.
www.speednchrome.com Facebook Instagram
Visits: 4.0K
Thanks, I had Valley build my driveshaft and liked their work.
Don
Visits: 618
If your building a Yblock I'd use Tim McMaster. He's down in Visalia. http://yblockguy.com/One of the best in the Modesto area would be Valley Balancing & Machine. Valley Balancing & Machine1900 Herndon Rd
Ceres, CA 95307 (209) 538-8956
Visits: 4.0K
I'm in Modesto also and will be needing a machine shop before long and was wondering which one you're using.
Don
Visits: 618
Visits: 618
I am working a deal on some heads now and hope it all fall in line. Just waiting to see if they are posted heads or not. Hoping to confirm this weekend. I did get some parts ordered, stud kit for the main and heads, timing set and push rods. Should also get info on a four speed thats local that may work as well. He's supposed to be getting that checked.
Still looking for a bell housing and a "B" intake. But I may contact one of my fellow fabricators and have them built me an intake. We'll see how that works out.
This weekend we will be pulling some of the front end apart and getting measurements for the straight axle so I'll have a few pics to post up. If anyone is looking for 56 Ford parts, drop me a line, there will be a lot of stuff coming off the car that won't be used.
Posts: 3.0K,
Visits: 8.7K
That's gonna be neat.
Posts: 1.3K,
Visits: 9.2K
Lancer, if those are the 113s then you have the best ford heads out there for all around building.
-Gary Burnette-
