RB
Visits: 16.7K
Pressure is on Chuck... It better be at Norwalk so we can all drool over it...
Y block Billy
Posts: 1.6K,
Visits: 5.2K
Hey Hey RB, don't be drooling on that paint I put on for him!
Posts: 7.3K,
Visits: 204.6K
Rowen
Visits: 29.3K
Yeah baby!! That's what I'm talkin about!! Very, very nice Ted and Chuck! Can't wait to see the first video of her goin down the track!!
Rowen 55CV Woodland, Ca
Posts: 4.5K,
Visits: 37.1K
Daniel Jessup
Posts: 2.0K,
Visits: 119.0K
Wow! that is great! Give us the specs from that dyno run too when you can. That thing is going to turn some heads for sure...
Daniel JessupLancaster, California aka "The Hot Rod Reverend" check out the 1955 Ford Fairlane build at www.hotrodreverend.com
Posts: 4.5K,
Visits: 37.1K
I'm hoping Ted will chime in with the dyno record. I asked him to build it for easy street driving with oomph!
Posts: 7.3K,
Visits: 204.6K
MoonShadow (5/22/2017)
I'm hoping Ted will chime in with the dyno record. I asked him to build it for easy street driving with oomph! On Chuck’s engine, it’s 325 cubic inches with a small camshaft (Isky 228/238 grind on 110° lobe centers) and 8.55:1 static compression ratio. The dynamic compression ratio is 7.20:1. With the blower pulleys in a 10% underdrive configuration, the engine is making 377HP and 377TQ. With the pulleys reversed so it in a 10% overdrive configuration, the engine is making 428HP and 422TQ. Both of these sets of numbers are with a 650 dbl pmpr Holley. Switching to a 850 DP Holley and staying at the 10% overdrive configuration, the numbers jump up to 445HP and 426TQ.
Rowen
Visits: 29.3K
If I may ask Ted, at what RPM were those pulls from and too? Where were the peaks? Chuck, Ted, that motor is not only bad, it sure is pretty!! Nicely done all round!
Posts: 4.5K,
Visits: 37.1K
