Hoosier Hurricane (12/4/2013)
Ron:
The 3.56 ratio and the threaded end caps makes me wonder if you are looking at a '49-'56 third member.easey way to insure 9in is the lower capscrew holding the pot in can only be removed with a boxend (socket wont work.
my 57 ranchero has rear ujoint that is threaded,4 5/16 capscrews hold it to flange. tho it uses the smaller seal in the pot,so suspect a chang,also it is 3.25 ratio. tha cause of the leak was yoke not going on far enough.i solved by useing a 1/8 thick washer,trimed on the lath. worked great. also years ago i had a 57 merc it had the same yoke, but the gen 1 large seal.
some 1 may know when the small seal went into service. this Old stuff is a never ending learning curve,great fun
