The Dinnerhill -56 F100 Restoration thread....
Posted By jimcar-9 12 Years Ago
jimcar-9
Supercharged (217 reputation)Supercharged (217 reputation)Supercharged (217 reputation)Supercharged (217 reputation)Supercharged (217 reputation)Supercharged (217 reputation)Supercharged (217 reputation)Supercharged (217 reputation)Supercharged (217 reputation)
Posts: 89, Visits: 894
lyonroad (3/14/2014)
I borrowed mine from a guy with a machine shop.
I have been searching quite a few machineshops around where I live. Work as a designer and engineer so I have a network of machineshops but everyone has 16, 18, 20 mm but the 3/4" (19.05 mm) is harder to find that water in Sahara.
I guess I just haveto buy an adjustable one
Best regards Jimmy Carlsson, Fagersta (Sweden) Ford F100 1956, 272 , 3 manual with OD
Follow my restoration on http://dinnerhillspeedshop.blogspot.se/
jimcar-9
I actually found a fixed reamer in 19H7 that was spot on what i needed for the rear spring buhings, and all for free...... Thanks Håkan Karla Karlström.
Here are the latest updates:
jimcar-9
I really like how stiff suspension got sideways with new bushings and washers.
http://dinnerhillspeedshop.blogspot.se/2014/04/new-rear-axle-second-mockup.html
slick56
Last Active: 2 Weeks Ago
Posts: 460, Visits: 4.5K
How stiff ?
BigGrin
South Australia
jimcar-9
slick56 (4/3/2014)
How stiff ?
BigGrin
Ha ha ha well I wont go there!!! I was amazed about the big difference, worn vs new
jimcar-9
Modifications to the CPP dual master cylinder brackets its all done.
jimcar-9
Well guys .... I have been bad on the updates so here it goes
http://dinnerhillspeedshop.blogspot.se/2014/05/old-timing-set-need-new-one.html
http://dinnerhillspeedshop.blogspot.se/2014/06/engine-has-been-completely-disassembled.html
http://dinnerhillspeedshop.blogspot.se/2014/07/nos-front-leaf-springs-taaa-5310-a.html
http://dinnerhillspeedshop.blogspot.se/2014/07/nos-2-belt-harmonic-balancer-ebay-find.html
http://dinnerhillspeedshop.blogspot.se/2014/07/front-suspension-chassie-bushing.html
http://dinnerhillspeedshop.blogspot.se/2014/07/front-spring-shackle-and-pins.html
http://dinnerhillspeedshop.blogspot.se/2014/07/front-suspension-test-assembly.html
http://dinnerhillspeedshop.blogspot.se/2014/07/rear-upper-engine-suppert-mounts.html
http://dinnerhillspeedshop.blogspot.se/2014/08/setting-pinion-angle-for-spring-perch.html
Thats all for one. I am getting really close to media blast and paint for the chassie, JJJjiiiiiihhhaaaa
jimcar-9
A few more updates
Small steps
http://dinnerhillspeedshop.blogspot.se/2014/08/rear-axle-spring-perch-welding.html
http://dinnerhillspeedshop.blogspot.se/2014/08/nos-waterpump-rebuild-kit.html
http://dinnerhillspeedshop.blogspot.se/2014/08/door-hinges-what-condition-are-they-in.html
http://dinnerhillspeedshop.blogspot.se/2014/08/nos-delbar-reflector-flare-kit.html
On thursday this week chassie is of for media blast and paint
jimcar-9
Some updates
Broken frame rivets
http://dinnerhillspeedshop.blogspot.se/2014/08/broken-frame-rivets.html
Made some riveting tools
http://dinnerhillspeedshop.blogspot.se/2014/09/riveting-tools.html
Re-riveting
http://dinnerhillspeedshop.blogspot.se/2014/09/re-riveting.html
Loading chassie parts for paint
http://dinnerhillspeedshop.blogspot.se/2014/09/loading-up-for-paint-chassie.html
Found some rare NOS original outside rear view mirrors
http://dinnerhillspeedshop.blogspot.se/2014/09/1st-nos-mirror-head-and-arm.html
http://dinnerhillspeedshop.blogspot.se/2014/09/2nd-nos-mirror-complete-assembly.html
Visited the Hot rod Rumble in Filipstad
http://dinnerhillspeedshop.blogspot.se/2014/09/hot-rod-rumble-filipstad-2014.html
Picked up the cjassie from mediablast and paint
http://dinnerhillspeedshop.blogspot.se/2014/10/picking-up-frame-from-media-blast-and.html
Rear spring bitumen based lubrication
http://dinnerhillspeedshop.blogspot.se/2014/10/rear-spring-lubrication.html
Thanks for now
stuey
Supercharged (855 reputation)Supercharged (855 reputation)Supercharged (855 reputation)Supercharged (855 reputation)Supercharged (855 reputation)Supercharged (855 reputation)Supercharged (855 reputation)Supercharged (855 reputation)Supercharged (855 reputation)
Posts: 442, Visits: 3.8K
Hi there
keep posting I am really enjoying following  the rebuild.  I have the Dinnerhill web site on my list of favorites.
where did you get the 9" local or import? an improvement I am considering but shipping is a major consideration these days
stuey
UK
