By jimcar-9 - 12 Years Ago
I noticed I haden´t put up my web page on here before just bits and pieces in other threads so here it goes
Main page
http://dinnerhillspeedshop.blogspot.se/
Latest update. Almost down to the bare frame.
http://dinnerhillspeedshop.blogspot.se/2013/10/tear-down.html
The plan is to have a restored chassie until next summer/automn, then the engine build and Transmission will come for the following 1 year.
Basic plan, we will see how long it will hold
Hope you like it
Now the I am down to the bare frame.
http://www.blogger.com/blogger.g?blogID=3015671280419822763#allposts
Some additional updates:
By the way, thanks Kevin for the parts they arrived to my Daly City contact yesterday
http://dinnerhillspeedshop.blogspot.se/search/label/OEM%20Optional%20parts
Ebay find
http://dinnerhillspeedshop.blogspot.se/search/label/Period%20correct%20%20parts
By stuey - 12 Years Ago
looks a real class resto job found the front bumper tow hooks realy interesting, never seen them before. stuey
Yes the tow hooks made my day, I am probably the only one in Sweden that will find them interesting but what the heck it is my truck
By texasmark1 - 12 Years Ago
great posts and pics!
keep at it...
Mark
By vntgtrk - 11 Years Ago
stuey (12/11/2013) looks a real class resto job found the front bumper tow hooks realy interesting, never seen them before. stuey
They're usually only found on Chebbies. They need to be towed all the time whereas a Ford doesn't
By jimcar-9 - 11 Years Ago
Ha ha ha you right about the chebby.....
Thanks guys, heres some updates on the rear springs. Just cleaning so far, waiting for parts
http://dinnerhillspeedshop.blogspot.se/2014/01/leaf-springs-rear.html
This was a nice one, can someone see the mistake some previous owner have done???
http://dinnerhillspeedshop.blogspot.se/2014/01/drum-brakes-front-whats-up.html
By Lord Gaga - 11 Years Ago
Leading shoes on one side, trailing on the other? NICE!
Lord Gaga (1/16/2014)
Yep
You are spot on.......
Can someone give me a hint on why I dont get an update on e-mail when someone makes a post in this thread despite me having it on the "Favorite list" here on the forum????
By slick56 - 11 Years Ago
jimcar-9 (1/22/2014) [quote]Lord Gaga (1/16/2014) [quote]jimcar-9 (1/16/2014)
Hey Jimmy, i am having the same problem.
There is a bug in the system and the site owner is waiting on new software.
some info here...
http://forums.y-blocksforever.com/Topic98266.aspx?PageIndex=2
By snowcone - 11 Years Ago
Ha, I found a similar problem on mine when I pulled it down. Previous guy had fitted a front brake shoe to the rear brakes on each side and still managed to get the narrower drum over them.
Slick56: thanks for the update. I really hope they sort the bug out.
Snowcone: It seems like it´s really hard getting the little shoe, big shoe right
Anyway here are the latest updates:
DinnerHill SpeedShop: Front axle tear down
DinnerHill SpeedShop: Front wheel hub dissassembly
DinnerHill SpeedShop: Front axle media blasting
DinnerHill SpeedShop: Original Color Codes
Some updates
Dinnerhillspeedshop: Status check engine
Dinnerhillspeedshop: Brake & clutch assembly media blast
Dinnerhillspeedshop: Adjusting worn rear Y-hangers
DinnerHill SpeedShop: CPP Dual master cylinder, Drum Drum mockup
I got some help on the forum to realise that I hadn´t made the homework and that I should have bought a clutch shaft elongation kit, but I will probably go with the modification of the stock bracket and offset that the same amount to line up the MC and the brake pedal.
DinnerHill SpeedShop: New rear axel first mockup
DinnerHill SpeedShop: Rear sway bar, mockup, first try
DinnerHill SpeedShop: Rear leaf spring perch modifications #1
DinnerHill SpeedShop: Leaf spring perch modification #2
DinnerHill SpeedShop: Y-hangers bushing replacement part #1
Short questions: Is it mandatory to ream the Y-hangers and the spring eye bushings after installation? or have I just gotten a tight set?
DinnerHill SpeedShop: Eaton power steering pump
By lyonroad - 11 Years Ago
I had to ream mine.
Thanks!! I am in the process of finding a reamer that I could borrow, an adjustable reamer are alot more expencive to buy over her than on your side......unfortunatelly
I didn't buy one I borrowed it. I think they are expensive here too.
I have really tried to find one in the 12,000 citizen town I live in and so far I have come up with ZIP......... so I have found a new one for sale for about $40 delivered home, and I must say that that was a really good deal. I am leaning towards that at the moment. 4-6 days for delivery.
I borrowed mine from a guy with a machine shop.
lyonroad (3/14/2014) I borrowed mine from a guy with a machine shop.
I have been searching quite a few machineshops around where I live. Work as a designer and engineer so I have a network of machineshops but everyone has 16, 18, 20 mm but the 3/4" (19.05 mm) is harder to find that water in Sahara.
I guess I just haveto buy an adjustable one
I actually found a fixed reamer in 19H7 that was spot on what i needed for the rear spring buhings, and all for free...... Thanks Håkan Karla Karlström. Here are the latest updates:
I really like how stiff suspension got sideways with new bushings and washers.
http://dinnerhillspeedshop.blogspot.se/2014/04/new-rear-axle-second-mockup.html
How stiff ?
slick56 (4/3/2014) How stiff ?
Ha ha ha well I wont go there!!! I was amazed about the big difference, worn vs new
Modifications to the CPP dual master cylinder brackets its all done.
Well guys .... I have been bad on the updates so here it goes
http://dinnerhillspeedshop.blogspot.se/2014/05/old-timing-set-need-new-one.html
http://dinnerhillspeedshop.blogspot.se/2014/06/engine-has-been-completely-disassembled.html
http://dinnerhillspeedshop.blogspot.se/2014/07/nos-front-leaf-springs-taaa-5310-a.html
http://dinnerhillspeedshop.blogspot.se/2014/07/nos-2-belt-harmonic-balancer-ebay-find.html
http://dinnerhillspeedshop.blogspot.se/2014/07/front-suspension-chassie-bushing.html
http://dinnerhillspeedshop.blogspot.se/2014/07/front-spring-shackle-and-pins.html
http://dinnerhillspeedshop.blogspot.se/2014/07/front-suspension-test-assembly.html
http://dinnerhillspeedshop.blogspot.se/2014/07/rear-upper-engine-suppert-mounts.html
http://dinnerhillspeedshop.blogspot.se/2014/08/setting-pinion-angle-for-spring-perch.html
Thats all for one. I am getting really close to media blast and paint for the chassie, JJJjiiiiiihhhaaaa
A few more updates
Small steps http://dinnerhillspeedshop.blogspot.se/2014/08/rear-axle-spring-perch-welding.html http://dinnerhillspeedshop.blogspot.se/2014/08/nos-waterpump-rebuild-kit.html http://dinnerhillspeedshop.blogspot.se/2014/08/door-hinges-what-condition-are-they-in.html http://dinnerhillspeedshop.blogspot.se/2014/08/nos-delbar-reflector-flare-kit.html
On thursday this week chassie is of for media blast and paint
Some updates
Broken frame rivets http://dinnerhillspeedshop.blogspot.se/2014/08/broken-frame-rivets.html
Made some riveting tools http://dinnerhillspeedshop.blogspot.se/2014/09/riveting-tools.html
Re-riveting http://dinnerhillspeedshop.blogspot.se/2014/09/re-riveting.html
Loading chassie parts for paint http://dinnerhillspeedshop.blogspot.se/2014/09/loading-up-for-paint-chassie.html
Found some rare NOS original outside rear view mirrors http://dinnerhillspeedshop.blogspot.se/2014/09/1st-nos-mirror-head-and-arm.html http://dinnerhillspeedshop.blogspot.se/2014/09/2nd-nos-mirror-complete-assembly.html
Visited the Hot rod Rumble in Filipstad http://dinnerhillspeedshop.blogspot.se/2014/09/hot-rod-rumble-filipstad-2014.html
Picked up the cjassie from mediablast and paint http://dinnerhillspeedshop.blogspot.se/2014/10/picking-up-frame-from-media-blast-and.html
Rear spring bitumen based lubrication http://dinnerhillspeedshop.blogspot.se/2014/10/rear-spring-lubrication.html
Thanks for now
By stuey - 11 Years Ago
Hi there keep posting I am really enjoying following the rebuild. I have the Dinnerhill web site on my list of favorites. where did you get the 9" local or import? an improvement I am considering but shipping is a major consideration these days stuey UK
stuey (11/11/2014)
Hi Stuey
Thats really cool to hear, my site on a favourite list......COOL
I ordered the rear from a company called quick performance in Ames IA
https://www.google.se/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0CCEQFjAA&url=http%3A%2F%2Fwww.quickperformance.com%2F&ei=atphVODsE8mkPJbSgeAK&usg=AFQjCNEYkwBCvEVhzld1fSQA1ipX-ZEo9g&sig2=nxd0Qz3BC47KV0jE9dVn0g&bvm=bv.79189006,d.d2s
The guy I talked to was Brydon Papenberg, It was ordered as a complete package with everything new except the brake shield, housing, centre part housing and yoke, these parts was refurbished and the axle housing had new tubings and ends well you can read everything about it here
http://dinnerhillspeedshop.blogspot.se/2013/11/rear-axel.html The shipping from Ames to San Fransisco was only $100 !! and there I have a friend that ships old american iron over to sweden so I got a good real on the shipping home to sweden....
All in all I have about $2300 in that rear, home in my garage. That´s not even the start price when ordering the same parts at the know places like curries enterprice etc on the west coast. Their shipping inside california was more than I payed for the entire shipping from Ames to my front lawn......
$2300 is not pocketchange but I will not have to worry about it anymore as it is rated about 750hp, way more than I will ever put in to this little truck. I also got it to factory dimension specs and a torsion diff witch will make it nice to drive in the snow....... ;-)
Verrey good presentation,we in bc canada would never find a core in such good shape, will be a great truck cliff
Well
I can only say that I was lucky when I bought it.
It was 8 years ago I had gotten my first job and I had been wanting one of these for several years and then an add showed up not that far away, about 3 hours drive. So Me and my girlfriend (today wife) hit the road a friday after work. I was sold the second I saw it. All the "buy old cars rules" where out the window, I just needed to have it.
The only rust repair I have found is about 3 inches on the top left drip rail to roof section. and that has been fixed by the first swedish owner in the earlie 90´s.
So I guess I was a lucky guy LOL
A few of the latest updates
http://dinnerhillspeedshop.blogspot.se/2014/11/front-suspension-final-assembly.html
http://dinnerhillspeedshop.blogspot.se/2014/11/left-some-parts-for-electro-zinc-plating.html
http://dinnerhillspeedshop.blogspot.se/2014/11/spindel-assembly.html
http://dinnerhillspeedshop.blogspot.se/2014/11/hd-tie-rod-assembly.html
By jimcar-9 - 10 Years Ago
Some updates.....
http://dinnerhillspeedshop.blogspot.se/2014/12/rear-tow-hook-and-bumper-bracket-design.html
http://dinnerhillspeedshop.blogspot.se/2015/01/reaming-clutch-shaft-bushings.html
http://dinnerhillspeedshop.blogspot.se/2015/01/drag-link-assembly.html
By ian57tbird - 10 Years Ago
Looks great, very nice work. Appears like maybe the spring mounting points set the caster.
ian57tbird (1/16/2015)
Hmmmm?? I dont follow you on this one???
The frame is stock and the springs are NOS, Front axel is stock. The angle shims between the axle and springs are the only thing that sets the caster, and of course the angle of the chassie. There are no built in caster in the front axle as it is equal front to back.
At least as far as I know....
By MoonShadow - 10 Years Ago
As I recall any major requirement for caster and camber was accomplished by heating the axle and bending it. A lot of old front end shops had a anchor built into the floor where they could attach a chain to hold the axle while tweaking it. Wedges would do for minor adjustments I'm sure. Chuck
Hi Jimmy. Just from the pics it appears to me like the eyelets on the springs are higher on the front than the rear but it might be an optical illusion.
ian57tbird (1/17/2015)
You are right about that, the frame is not level on the jacks and there are no weights on the chassie so when it´s all done the front shackels will be pointing slightly forward leveling the eyelets
http://dinnerhillspeedshop.blogspot.se/2015/01/steering-column-modifications-design.html
http://dinnerhillspeedshop.blogspot.se/2015/01/electro-zinc-plated-parts-has-arrived.html
http://dinnerhillspeedshop.blogspot.se/2015/01/some-general-progress-pictures.html
http://dinnerhillspeedshop.blogspot.se/2015/01/front-axle-bumpstop-assembly.html
http://dinnerhillspeedshop.blogspot.se/2015/01/rear-axle-lower-damper-mount.html
http://dinnerhillspeedshop.blogspot.se/2015/02/front-wheel-hub-assembly.html
http://dinnerhillspeedshop.blogspot.se/2015/02/wheel-cylinder-painting.html
http://dinnerhillspeedshop.blogspot.se/2015/03/rear-axle-final-asssembly.html
http://dinnerhillspeedshop.blogspot.se/2015/03/strength-calculations-rear-tow-hitch.html
http://dinnerhillspeedshop.blogspot.se/2015/03/clutch-and-brake-pedal-assembly-done.html
Thats all for now.....
