The Dinnerhill -56 F100 Restoration thread....
Posted By jimcar-9 12 Years Ago
jimcar-9
Supercharged (217 reputation)Supercharged (217 reputation)Supercharged (217 reputation)Supercharged (217 reputation)Supercharged (217 reputation)Supercharged (217 reputation)Supercharged (217 reputation)Supercharged (217 reputation)Supercharged (217 reputation)
Posts: 89, Visits: 894
Lord Gaga (1/16/2014)
jimcar-9 (1/16/2014)
This was a nice one, can someone see the mistake some previous owner have done???
http://dinnerhillspeedshop.blogspot.se/2014/01/drum-brakes-front-whats-up.html
Leading shoes on one side, trailing on the other? NICE!
Yep
You are spot on.......
Can someone give me a hint on why I dont get an update on e-mail when someone makes a post in this thread despite me having it on the "Favorite list" here on the forum????
Best regards Jimmy Carlsson, Fagersta (Sweden) Ford F100 1956, 272 , 3 manual with OD
Follow my restoration on http://dinnerhillspeedshop.blogspot.se/
slick56
Posts: 460, Visits: 4.5K
jimcar-9 (1/22/2014)
[quote]Lord Gaga (1/16/2014)
[quote]jimcar-9 (1/16/2014)
Hey Jimmy, i am having the same problem.
There is a bug in the system and the site owner is waiting on new software.
some info here...
http://forums.y-blocksforever.com/Topic98266.aspx?PageIndex=2
South Australia
snowcone
Supercharged (364 reputation)Supercharged (364 reputation)Supercharged (364 reputation)Supercharged (364 reputation)Supercharged (364 reputation)Supercharged (364 reputation)Supercharged (364 reputation)Supercharged (364 reputation)Supercharged (364 reputation)
Posts: 169, Visits: 5.9K
Ha, I found a similar problem on mine when I pulled it down.
Previous guy had fitted a front brake shoe to the rear brakes on each side and still managed to get the narrower drum over them.
Gary - 1958 Star Customline and 1940 Ford Deluxe Hotrod
jimcar-9
Slick56: thanks for the update. I really hope they sort the bug out.
Snowcone: It seems like it´s really hard getting the little shoe, big shoe right Crazy
Anyway here are the latest updates:
DinnerHill SpeedShop: Front axle tear down
DinnerHill SpeedShop: Front wheel hub dissassembly
DinnerHill SpeedShop: Front axle media blasting
DinnerHill SpeedShop: Original Color Codes
jimcar-9
Some updates
Dinnerhillspeedshop: Status check engine
Dinnerhillspeedshop: Brake & clutch assembly media blast
Dinnerhillspeedshop: Adjusting worn rear Y-hangers
DinnerHill SpeedShop: CPP Dual master cylinder, Drum Drum mockup
I got some help on the forum to realise that I hadn´t made the homework and that I should have bought a clutch shaft elongation kit, but I will probably go with the modification of the stock bracket and offset that the same amount to line up the MC and the brake pedal.
DinnerHill SpeedShop: New rear axel first mockup
DinnerHill SpeedShop: Rear sway bar, mockup, first try
DinnerHill SpeedShop: Rear leaf spring perch modifications #1
DinnerHill SpeedShop: Leaf spring perch modification #2
DinnerHill SpeedShop: Y-hangers bushing replacement part #1
Short questions: Is it mandatory to ream the Y-hangers and the spring eye bushings after installation? or have I just gotten a tight set?
DinnerHill SpeedShop: Eaton power steering pump
lyonroad
Posts: 703, Visits: 3.1K
jimcar-9 (3/11/2014)
Some updates
I had to ream mine.
Mark
1956 Mercury M100
1955 Ford Fairlane Club Sedan
Delta, British Columbia
jimcar-9
Thanks!! I am in the process of finding a reamer that I could borrow, an adjustable reamer are alot more expencive to buy over her than on your side......unfortunatelly
lyonroad
I didn't buy one I borrowed it. I think they are expensive here too.
Mark
1956 Mercury M100
jimcar-9
I have really tried to find one in the 12,000 citizen town I live in and so far I have come up with ZIP......... so I have found a new one for sale for about $40 delivered home, and I must say that that was a really good deal. I am leaning towards that at the moment. 4-6 days for delivery.
lyonroad
I borrowed mine from a guy with a machine shop.
Mark
1956 Mercury M100
