Visits: 1.0K
Looks good!! Lets get a deal goin.
Fomoco Low Life
Posts: 7.4K,
Visits: 205.6K
Here are some additional pictures. .. ..  .. ..  .. ..
Visits: 1.0K
Yes I would like to see more pics of it installed on the truck and off. I am definitely interested. Thank you!
Fomoco Low Life
Visits: 1.0K
Email sent. Thanks
Fomoco Low Life
Posts: 7.4K,
Visits: 205.6K
I have the 1963 F100 pieces if you think they will work. They are the pieces pictured above and were just removed from the engine/trans assy. I do have some more detailed pictures and can post them if that helps. Feel free to email me directly if interested in the linkages. My email info is located under contact information at http://www.eatonbalancing.com/ .
Posts: 7.4K,
Visits: 205.6K
56 ford custom (12/2/2013) I have looked around here for some time with no luck! Where are you located?
Visits: 1.0K
junkyardjeff (12/1/2013) I would think any linkage off a 57 and up Y block that has a automatic trans could be made to work,take a look at 60 to 62 galaxies. If you can not find any a local yard has a few and could be a excuse to go back and walk around.I have looked around here for some time with no luck!
Fomoco Low Life
Visits: 3.4K
Visits: 1.0K
Ted (12/1/2013)
Here are pics of the linkage on a 1963 F100 engine. They may help.   This should help! Thank you! What other vehicle will the kickdown rod work off of?
Fomoco Low Life
Posts: 7.4K,
Visits: 205.6K
