1960 f100 with original 292 yblock/fordomatic (linkage & bellcrank issue)
http://forums.y-blocksforever.com/Topic96775.aspx
By 56 ford custom - 12 Years Ago
Hey hows it going guys? I have been building my 60 for a while. Now i am at the stage or installing the y block and trans in my pickup. I misplaced the bellcrank and linkages for the auto trans. I found some in my fairlane stash but cant remember which one is correct for my truck. Does anyone here have a 59 or 60 f100 with the same factory set up? If so can you please post pictures? Or if you have a shop manual? I am trying to get this truck assembled but no luck. Thanks!
By Ted - 12 Years Ago
Here are pics of the linkage on a 1963 F100 engine. They may help.
Ted (12/1/2013)
This should help! Thank you! What other vehicle will the kickdown rod work off of?
I would think any linkage off a 57 and up Y block that has a automatic trans could be made to work,take a look at 60 to 62 galaxies. If you can not find any a local yard has a few and could be a excuse to go back and walk around.
junkyardjeff (12/1/2013)
I have looked around here for some time with no luck!
56 ford custom (12/2/2013)
Where are you located?
I have the 1963 F100 pieces if you think they will work. They are the pieces pictured above and were just removed from the engine/trans assy. I do have some more detailed pictures and can post them if that helps. Feel free to email me directly if interested in the linkages. My email info is located under contact information at
http://www.eatonbalancing.com/ .
Email sent. Thanks
Yes I would like to see more pics of it installed on the truck and off. I am definitely interested. Thank you!
Here are some additional pictures. .. ..
Looks good!! Lets get a deal goin.
