Yet Another PCV Question
Posted By '59Edsel 13 Years Ago
'59Edsel
Posted 13 Years Ago
Supercharged (422 reputation)Supercharged (422 reputation)Supercharged (422 reputation)Supercharged (422 reputation)Supercharged (422 reputation)Supercharged (422 reputation)Supercharged (422 reputation)Supercharged (422 reputation)Supercharged (422 reputation)
Posts: 163, Visits: 3.5K
Awesome. Now, since my vacuum wipers are connected to it at the moment, would it be a problem it I had both the pvc valve and wipers connected to that one port at the same time?
http://oi43.tinypic.com/vyxn49.jpg
The Master Cylinder
Posted 13 Years Ago
Posts: 974, Visits: 6.2K
oldcarmark (10/28/2013)
The Master Cylinder (10/27/2013)
[quote]oldcarmark (10/27/2013)
[quote][b]
If you want a suugestion for a starting point for a PCV valve I used one for a 302 Ford initially. Too much airflow so I went to one for a 4 cylinder which worked very well.
What's confuses the matter is the Microgard PCV-202 that Ted suggests is list for any from a 302 Ford all the way up to a 460 and everything in between... w00t[/quote]
Like I said its trial and error.What works on one engine may not work on another.Like everything else fuel related there are variables like camshaft,timing,etc.I found with my stock engine the 302 valve flowed too much air.The idle was terrible.The 4 cylinder one has a smaller size passageway.You can also restrict the airflow as I mentioned if its too lean.The PCV valve is just a flow control depending on vacuum and internal size.
Mark, what I was referring to is the same PCV valve is used in such a wide range of engine sizes, not that the one Ted suggested would not work on a 292.
stuey
Posted 13 Years Ago
Supercharged (859 reputation)Supercharged (859 reputation)Supercharged (859 reputation)Supercharged (859 reputation)Supercharged (859 reputation)Supercharged (859 reputation)Supercharged (859 reputation)Supercharged (859 reputation)Supercharged (859 reputation)
Last Active: 10 Months Ago
Posts: 444, Visits: 3.8K
i think it was the guys from Finland (Hollow heads) spotted this one
http://mewagner.com/?page_id=444
stuey
ian57tbird
Posted 13 Years Ago
Posts: 502, Visits: 21.7K
Why do you want a PCV valve?
GREENBIRD56
Posted 13 Years Ago
Posts: 1.7K, Visits: 102.7K
I understand the want / need for a PCV - but why would someone consider a US$129 priced "dual path" version?
stuey
Posted 13 Years Ago
i don't know maybe its techy, adjustable its bright and shiny.....Smile
now tell me something why do some PCV valves have two hose barbs?
stuey
The Master Cylinder
Posted 13 Years Ago
ian57tbird (10/28/2013)
Here are some good reasons;
• Properly ventilates crankcase, resulting in cleaner oil and cleaner engine internals
• Reduces emissions
• Reduces moisture and acidic vapors in your engine’s crankcase
Posted 13 Years Ago
Posts: 3.8K, Visits: 33.4K
Have you ever noticed that gas fume smell in your garage when the car has been sitting enclosed for any length of time?Thats from the open crankcase having the Road Draft Tube.Install a PCV and close off the opening where the Draft Tube was(or still is for appearance only blocked off) and that smell is gone.Just one of several reasons for installing one.
Posted 13 Years Ago
It would be interesting to find out if that expensive valve is of any benefit. How would you quantify that in order to test it against other off-the-shelf valves? How do you know that you have the "right" pcv valve?
ian57tbird
Posted 13 Years Ago
I only thought they were for emissions. I don't have problems with fuel smell. How does it achieve a cleaner crankcase?
