T5 5speed trans. Will it bolt to my 56 Ford pass. 292 y-block??
Posted By kari613 13 Years Ago
kari613
Posted 13 Years Ago
Turbocharged (64 reputation)Turbocharged (64 reputation)Turbocharged (64 reputation)Turbocharged (64 reputation)Turbocharged (64 reputation)Turbocharged (64 reputation)Turbocharged (64 reputation)Turbocharged (64 reputation)Turbocharged (64 reputation)
Posts: 11, Visits: 299
I have a 56 Fairlane with a stock 292 v8. 3 speed manual trans. Will a Jeep 5 speed t5 bolt up to my 292 y-block? What will I need to make this swap? Thanks, Bill
Posted 13 Years Ago
By the most literal interpretation of "bolt up," meaning that you just bolt things on, no cutting, no grinding, no clearancing etc, there is no such thing for any of those older cars. I can't tell you exactly what will be required for your '56 but expect it to l be more than simply bolting things up.
If the input shaft length is sufficient, it will bolt up to the engine. It will need an adapter. If the Jeep T5 bolt pattern is unique, it will probably have to be a custom made adapter.
John Mummert
Posted 13 Years Ago
Posts: 919, Visits: 7.5K
This adapter will bolt a Ford T5 to your bellhousing. Will work if a Jeep T5 has the same bolt pattern.
http://ford-y-block.com/t5in-cars-bird.htm
http://ford-y-block.com/T5TB.JPG
