lincoln Teapot
Posted By pegleg 13 Years Ago
Posted 13 Years Ago
Anybody have a 56 lincoln Teapot, I need a float bowl. will take all or part, what ever you have.
carl
Posted 13 Years Ago
Posts: 1.2K, Visits: 20.6K
pegleg (9/10/2013)
Frank is the float bowl different on a 56 Ford t pot,i have some spare parts for them Carl
Posted 13 Years Ago
Last Active: 1 hour ago
Posts: 4.6K, Visits: 38.8K
Frank,
Did you get my PM's? Chuck
speedster1
Posted 13 Years Ago
Supercharged (78 reputation)Supercharged (78 reputation)Supercharged (78 reputation)Supercharged (78 reputation)Supercharged (78 reputation)Supercharged (78 reputation)Supercharged (78 reputation)Supercharged (78 reputation)Supercharged (78 reputation)
Posts: 36, Visits: 336
Most tea pot carbs look the same.
55 tea pot did have the choke on the intake manifold, so no place to bolt a chock on a 55 carb.
Some of the Lincoln carbs are modified for use on E & F engines to my best knowledge.
One sure fire thing, the top body of the carb which has the chock butterflies for E & F, and like the Lincoln carbs, >>>that body part is taller than a normal/typical teapot carb. One other easy and noticeable thing, a regular tea pot has rounded edges on its choke butterflies, and the performance E& F & Lincoln has squared off edges at the bottom.
I have performance tea pot ones here, and a Lincoln teapot, for a few F's being worked on, only reason I know guys.
John
Is this the worlds first exotic automobile? The 1935 Harris fwd speedster, No heavier, higher, wider, taller or longer than an AC Cobra, but many many decades before.
http://www.autopuzzles.com/forum/index.php?topic=11958.0
Posted 13 Years Ago
carl (9/11/2013)
pegleg (9/10/2013)
Carl, I think it's the same, do youhave one with a threaded needle seat? Some were a slide in arrangement.
speedster1
Posted 13 Years Ago
pegleg ,
Yes, they are most definitely different !!
Regards,
John
Posted 13 Years Ago
I tend to think the float bowls were the same as the smaller carbs. The choke housing is different as is the throttle housing.
speedster1
Posted 13 Years Ago
pegleg,
You got me thinking, so I went and measured a "regular t pot" >> and then the Lincoln, E & F carbs here..
From the aluminum base body of both of the carbs, to the top of the carbs, there is exactly 1/2 inch difference in height between the reg t pot, to the hipo t pot.
I measured from the rim of where the air cleaner gasket sits.
Never measured anything in-between, maybe the float bowls are the same?
I never noticed the difference until one day when I noticed the chock butterfly differences.
Warm regards,
John
Posted 13 Years Ago
i think so. Soon as i find a good one I'll find out. Hoosier told me the diff seems to be the choke housing, and 99% of the time he's correct.
yalincoln
Posted 13 Years Ago
Supercharged (581 reputation)Supercharged (581 reputation)Supercharged (581 reputation)Supercharged (581 reputation)Supercharged (581 reputation)Supercharged (581 reputation)Supercharged (581 reputation)Supercharged (581 reputation)Supercharged (581 reputation)
Last Active: 4 days ago
Posts: 381, Visits: 4.9K
hi, only the f code is like the Lincoln, the e code are like a standard carb. also the 55 linc. carb was like the standard but it was larger than a standard carb, it has larger secondaries, about half way between a standard and a linc. for cfm, also frank, ford and IH used the bigger carbs on trucks, only with a governer, the floats might be the same as the linc. i'll check when I get a chance. they used them on trucks well into the 60's. the truck carbs are a good sourse for bigger butterflys in a standard carb.
