The Master Cylinder
Visits: 6.2K
charliemccraney (9/8/2013)
The Master Cylinder (9/4/2013) Speaking of which, will a Ford small block distributor fit in a Y-Block? Maybe using a Y-Block shaft or something?I have a Duraspark body in mine right now so it definitely did not come from a Y-Block. Not sure if it is a small block or big block, but I think the bodies are all the same. To the best of my knowledge, the shaft and gear are the parts that are different. Thanks Charlie, that interesting. That's what I was thinking to put a Y-Block shaft in a SBF (or BBF??) I'm having a difficult time locating a remanufactured Y-Block distributor. Does anyone know if bushing are available for distributors. I could change out bushings if I had the parts and see NOS Y-Block gears on epay occasionally. Just letting my mind wander while doing "Honey Do's". Should be at the beach but I see the "Marine Layer" is coming in. Oh, enough day dreaming, back to work.
Talkwrench
Visits: 23.2K
The Master Cylinder
Visits: 6.2K
Haha, Yes, Mr. Gasket springs. Where did Grant come from? I'm losing it.
Anyway, I don't see any screws? The whole points plate turns with the vacuum advance arm... and with the straight arm it doesn't appear it would line up with the Per III pin.
Talkwrench
Visits: 23.2K
slick56
Visits: 4.5K
Does anyone know if bushing are available for distributors. I could change out bushings if I had the parts and see NOS Y-Block gears on epay occasionally. These are on eBay at the moment, only 3 left... http://www.ebay.com.au/itm/130890962841?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
South Australia
slick56
Visits: 4.5K
Y block Billy
Posts: 1.6K,
Visits: 5.2K
The Y block and small block housings are similar, I have gotten many rebuilts for Y's and they came with later small block housings, so it is doable. However the advance plate you have is a 57 ball bearing type and may not fit the later housings but I think you could put the Y shaft in the later housing and use the later style advance plate.
slick56
Visits: 4.5K
I looked at putting the Y shaft in the windsor housing, but there is not enough room under the breaker plate for the y advance mechanism. I have a 59 truck engine with a dizzy in the back of the shed, i will have a look at that in a couple of weeks, when i get back - off this week on a 3000 mile road trip to see my son in Western Australia (by camper van, not '56)....
South Australia
GREENBIRD56
Visits: 102.7K
I don't believe the USA Y-block Autolites after '57 - have the ball bearing point plate - they have a pivoting plate base that screws into the body. The almost 180º mounting screw holes are shown here. I don't have a ball bearing plate in my pile of leftovers.......  I was wondering if you can put the later Motorcraft point plate (Windsor) into the earlier variety and use the earlier upper rotor shaft, cam, rotor and cap as is. You would be converting to the curved base points - or an electronic converter that fits that base. Have a safe trip cross country
Steve Metzger Tucson, Arizona
slick56
Visits: 4.5K
What year is this distributor Steve? Pertronix 3 would fit in this, but using the windsor vac advance if this has the straight arm. Thanks, will keep my eyes peeled for 'roos, camels and cows..
South Australia
