Accessing older topics.
Posted By The Master Cylinder 13 Years Ago
The Master Cylinder
Posted 13 Years Ago
Posts: 974, Visits: 6.2K
I am trying to access some older topics, specifically these that Ted listed that pertain to Rocker Arm oiling mods. When I select a thread I get an error message. Is there an easy way to access them or are they no longer available with the 'New and Improved" YBF? A lot of good info here...
http://forums.y-blocksforever.com/Uploads/Images/86755623-e031-449e-9998-f298.png
Example of error message;
http://forums.y-blocksforever.com/Uploads/Images/1f6c0d75-ea0d-42b5-a520-e073.png
Posted 13 Years Ago
Last Active: 1 hour ago
If you come across a link that attempts to go to the now defunct old forum, it can be edited within the browser bar so the post can be accessed at the new server. If the link is hidden as a hyperlink within a descriptive phrase as above, then you'll have to access the properties to get to the real link in which to edit the link.
The old address looks like this: http://www.y-blocksforever.com/forums/Topic38818-3-1.aspx
By editing the address so the“forums” portion is moved to the front of the link and the “www” is removed, many of the old links can be accessed. Here’s the edited link:
http://forums.y-blocksforever.com/Topic38818-3-1.aspx
Posted 13 Years Ago
Here are the above phrase links with the edited hyperlinks.
Oiling mods
Oil Flow Diagram
Center cam bearing
Timing chain oil trough
Pressurized rocker shafts
Pressurized rocker shaft more
Pressurized timing chain oiling
Rocker arm overflow tubes Pros
Rocker arm overflow tubes Cons
Rocker arm overflow tube More Pros
Grooving the center cam hole in the block
Slotting the rockershafts for improved oiling
Adding lifter valley holes for camshaft oiling
Valley holes for aiding crankcase evacuation
Drilling additional holes for oiling and/or venting
And here's the original thread which has also been corrected.
http://forums.y-blocksforever.com/FindPost65297.aspx
The Master Cylinder
Posted 13 Years Ago
Awesome, Ted. Thank you so much for the info and correction method if I have a problem in the future while doing a search.
Looks like I got some good reading (rereading?) for an overcast Sunday morning. (Good old SoCal "Marine Layer").Smooooth
