Rocker arm oiling modification
Posted By Missouri Mike 15 Years Ago
Missouri Mike
Supercharged (212 reputation)Supercharged (212 reputation)Supercharged (212 reputation)Supercharged (212 reputation)Supercharged (212 reputation)Supercharged (212 reputation)Supercharged (212 reputation)Supercharged (212 reputation)Supercharged (212 reputation)
Last Active: 13 Years Ago
Posts: 210, Visits: 1.2K
Hi Y guys
I'm looking for some input concerning the rocker arm modifications Gord McMillan did the article about. It was about pressurizing the rocker shafts by plugging the overflow pipes with a metered orifice.  He then advised drilling additional holes in the shafts.
Would one do this in addition to cutting the groove in the camshaft? Instead of cutting the camshaft groove? Or is it even necessary if you have a properly grooved cam with hard cam bearings?
Thoughts,comments, observations???????????
Missouri Mike
I'd rather be lucky than good.................
    but good ain't bad!!
marvh
Supercharged (615 reputation)Supercharged (615 reputation)Supercharged (615 reputation)Supercharged (615 reputation)Supercharged (615 reputation)Supercharged (615 reputation)Supercharged (615 reputation)Supercharged (615 reputation)Supercharged (615 reputation)
Posts: 513, Visits: 16.7K
I would take it was written for y block magazine way back when.
If so what issue was it.
marv
Posts: 3.7K, Visits: 323.8K
Issue #9.
Missouri Mike
    From the response (or lack of same) I would guess this is not a widely used modification.
    I'm just trying to gather all the information I can on the various options to keep those rockerarms properly lubed and functioning.
    I remember all too well the leaky oil line to the valve covers on the old 55 4 dr I drove in high school. But then we bought a very clean used 61 Ford 2dr sedan with a 292 sporting a 4 bbl and 3 on the tree with a (I believe) synchro first gear.  I was livin' large!!
     Mike of Missouri
Last Active: 1 hour ago
Here are some past threads that may help. Lots of reading here.
Oiling mods
Oil FlowDiagram
Center cam bearing
Timing chain oiltrough
Pressurized rockershafts
Pressurized rockershaft more
Pressurized timingchain oiling
Rocker armoverflow tubes Pros
Rocker armoverflow tubes Cons
Rocker armoverflow tube More Pros
Grooving thecenter cam hole in the block
Slotting the rockershafts for improved oiling
Adding liftervalley holes for camshaft oiling
Valley holes foraiding crankcase evacuation
Drillingadditional holes for oiling and/or venting
mctim64
Posts: 2.4K, Visits: 5.0K
This question seems to pop up a lot.  I'll bet Ted has those links all ready to copy and paste. Wink
Ketterbros
Supercharged (347 reputation)Supercharged (347 reputation)Supercharged (347 reputation)Supercharged (347 reputation)Supercharged (347 reputation)Supercharged (347 reputation)Supercharged (347 reputation)Supercharged (347 reputation)Supercharged (347 reputation)
Posts: 132, Visits: 2.8K
The only thing that Ted was not ready for was leaving his scoop in the middle of Denton Dragway...Spring Thaw.., and maybe the wheelstand at Kennedale Ford Shootout..??
Brother and I own/operate 1957 Ford Fairlane 312/4x2 and two 1963 Falcons 302 rollers carburated 600cfm, FE427 sitting in shed..
