Visits: 1.0K
Was there ever a manual shift bell housing for a 368 Lincoln? Are the motor mounts the same on a Y-block Ford?
E.J. in Havana FL
Visits: 3.4K
Yes,There is a stick bellhousing for a 368, the 57 368 mercurys used them. Also you can use a 302 332 truck bell,but they are heavy and need some machine work. The 368 motor mounts are not the same as a y-block
JUST A MIDNIGHT CRUISE DOWN THUNDER ROAD!!! TOM DRUMMOND MIDWEST DIRECTOR 57 FORD INTERNATIONAL
Visits: 78.1K
The only 1957 Mercs with the 368 engine and had the stick setup was a Bill Stroppe prepared M 335 optioned engine.
The bell housings on those stick ,368 ,M 335 equipted cars were made of aluminum with some serious beefy clutch linkage.
Supposedly only 100 of those M 335 engines along with the aluminum standard shift bell housings were produced from Stroppe"s shop.
Can you say "Hens Teeth" ?
Oldmics
Visits: 1.7K
aftermarket ones turn up on ebay every so often.
Posts: 1.8K,
Visits: 11.4K
314 (8/5/2013) aftermarket ones turn up on ebay every so often.Cragar made them once upon a time.
Posts: 1.8K,
Visits: 11.4K
aussiebill (8/5/2013)
Visits: 1.0K
Awesome bell housing, Thanks guys.... I'd love to have one of those in my '56 Ford....
E.J. in Havana FL
