368 Lincoln
Home
Keeping The Dream Alive!
Technical
http://forums.y-blocksforever.com/Topic84831.aspx
Print Topic
Close Window
By ejstith
13 Years Ago
Was there ever a manual shift bell housing for a 368 Lincoln? Are the motor mounts the same on a Y-block Ford?
By ecode ragtop
13 Years Ago
Yes,There is a stick bellhousing for a 368, the 57 368 mercurys used them. Also you can use a 302 332 truck bell,but they are heavy and need some machine work. The 368 motor mounts are not the same as a y-block
By Oldmics
13 Years Ago
The only 1957 Mercs with the 368 engine and had the stick setup was a Bill Stroppe prepared M 335 optioned engine.
The bell housings on those stick ,368 ,M 335 equipted cars were made of aluminum with some serious beefy clutch linkage.
Supposedly only 100 of those M 335 engines along with the aluminum standard shift bell housings were produced from Stroppe"s shop.
Can you say "Hens Teeth" ?
Oldmics
By 314
13 Years Ago
aftermarket ones turn up on ebay every so often.
By aussiebill
13 Years Ago
314 (8/5/2013)
Cragar made them once upon a time.
By aussiebill
13 Years Ago
aussiebill (8/5/2013)
314 (8/5/2013)
By ejstith
13 Years Ago
Awesome bell housing, Thanks guys.... I'd love to have one of those in my '56 Ford....
