Noob here in need of advice!
Posted By 1nickthegreek 13 Years Ago
1nickthegreek
Posted 13 Years Ago
Posts: 2, Visits: 6
Hello everyone, I have a '50 Ford customline 4 door sedan that I am turning into a custom (trying to achieve a "Mini-Merc" theme).
I am pulling the flathead and going to put in a Y block out of a 50's T-bird, not too interested in building it up too much, but want enough that I am not a snail...intend to back the Y block with an AOD, and need to know what adapter to use for the most painless installation. I am in a wheelchair, so will have to have others assemble for me so need something fairly straightforward LOL Blush
Raised on gasoline and still have tetraethyl coursing through my veins....
Posted 13 Years Ago
Posts: 4.6K, Visits: 39.5K
I used this adapter on mine several years ago and had no problems.
http://www.transmissionadapters.com/Pricing.htm
Our best friend in Y-Block parts is John Mummert in El Cajon, CA. He has this one:
http://www.ford-y-block.com/c4adapt.htm
While you are there take a look at ALL on the products John offers for Y's. Everything you need to build from mild to wild.
There are others around. Just do an EBAY search. Chuck
Lou
This post has been flagged as an answer
Posted 13 Years Ago
Last Active: 6 Months Ago
Posts: 564, Visits: 8.4K
A y-block into a 49/51 Ford or Merc is one of the hardest swaps you can do. In 1964 a friend and myself put a 56 T-Bird engine into a 51 Ford convertable, getting the engine and trans in is the easy part (as long as you have the motor mounts that bolt to the timming case cover) To start with you need a Thunderbird timming case cover, and oil pan, and a dropped tie rod. After that you must make everything, exhaust, oil filter, linkage. My friend's father had a big auto repair business and I was working part time in a michine shop, we must of had over a 150 hours in that car in the 4 months it took to finish. The upside...we put over 50,000 miles on that can in the next 3 years, with the only repair being a front seal in the engine.
1nickthegreek
Posted 13 Years Ago
Posts: 2, Visits: 6
Thank you very much Moon Shadow and Lou for your insights. Smile
slick56
Posted 13 Years Ago
Posts: 463, Visits: 4.5K
MoonShadow, how did you go mounting the AOD, JMummert advises that the ear on the block blocks the AOD starter motor hole?Did you modify the block?
South Australia
Posted 13 Years Ago
The Benedtson adapter is about 1" thick and comes with a high torque starter that bolts right up to it. There is a bit of grinding to do on the AOD bell housing but it is minimal. Makes starter swaps a whole lot easier. I did have to replace the starter once but its the same one that is used on the scrubs (sbc). Chuck
slick56
Posted 13 Years Ago
Thanks Chuck, gives me another option to get the revs down.
My ute with 302w, AOD and 3.55's is barely above idle @ 100kmh (65mph).
South Australia
AOD
Posted 13 Years Ago
It has enabled me to run 4:10 gears on the street and still have low Rpm on the highway. Only better option is a 5 or 6 speed and I like my automatics. Chuck
