Passenger side oil
Posted By sprink88 13 Years Ago
slick56
Posted 13 Years Ago
Posts: 463, Visits: 4.5K
Here is a link to a YouTube vid posted by '59Edsel showing the valve cover stud mod.Perhaps you can IM him for more info?
https://www.youtube.com/watch?v=7hFgpstD2y0
South Australia
sprink88
Posted 13 Years Ago
Supercharged (116 reputation)Supercharged (116 reputation)Supercharged (116 reputation)Supercharged (116 reputation)Supercharged (116 reputation)Supercharged (116 reputation)Supercharged (116 reputation)Supercharged (116 reputation)Supercharged (116 reputation)
Posts: 49, Visits: 661
well, went to an all Ford Junkyard today and pick up this little number. Do I need to pull the caps off the end or drill them out. Anyone know?
http://forums.y-blocksforever.com/Uploads/Images/a9e8bcb2-b11d-4bc9-a5de-bf55.jpghttp://forums.y-blocksforever.com/Uploads/Images/297c149f-420d-4b15-81a7-d7c4.jpg
now I know I have excellent oil on the drivers side, so I was going to plug the oil tube from the block and try rocker arm to rocker arm first.
1957 Fairlane
Posted 13 Years Ago
Last Active: 6 hours ago
Posts: 3.8K, Visits: 33.4K
The caps on the rocker shaft are press fit.Drill a small hole and use a sheet metal screw and vice grips to pop one out.
