56 Tbird needs to steer and stop a little better....
Posted By oldguy668 13 Years Ago
MarkMontereyBay
Posted 13 Years Ago
Posts: 733, Visits: 3.8K
The original 57Bird rear cylinders and the Granada pushrod. I have yet to try it out on wet pavement as Wilwood suggests but did a series of panic stops on dry pavement and it stops well enough. The master cylinder will have some interference with the battery box. You can modify that or relocate to the trunk like I did. I did this to also leave room for a hydraulic clutch cylinder to be mounted beside the brake master cylinder later when I get around to installing a 5speed manual trans but my 66 year old left knee is starting to complain about that idea.
[/quote]
57 Black Tbird 312/auto
oldguy668
Posted 13 Years Ago
Normally aspirated (27 reputation)Normally aspirated (27 reputation)Normally aspirated (27 reputation)Normally aspirated (27 reputation)Normally aspirated (27 reputation)Normally aspirated (27 reputation)Normally aspirated (27 reputation)Normally aspirated (27 reputation)Normally aspirated (27 reputation)
Posts: 9, Visits: 69
You need new knees, too, I guess. Mine gave out a few years ago and I haven't had them fixed yet. Too busy with cars...my '56 looks good enough from 30 feet, but there was an underdash fire that the previous owner "forgot" to tell me about. I should have the dash out today so I can start rewiring. I don't want to spend $500 for a dash harness, so it's a DIY deal this weekend.
skygazer
Posted 13 Years Ago
Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)
Posts: 112, Visits: 1.5K
MarkMontereyBay (4/25/2013)[hr... He is having problems with the dual master cylinder being too close to the stock log exhaust manifold. He said it is boiling the brake fluid....
I bought an inexpensive replica Corvette Disk/Drum MC on the 'bay (with a cool finned cover), along with a combo valve. I ended up cutting a spare brake push rod to fit. Installation pics here. The MC was a close fit with less than an inch clearance from the stock exhaust manifold. An extended heat shield would not fit, due to the width of the Corvette-style MC. I ended up cutting a scrap piece of self-adhesive fiberglass-backed aluminum heat shield material, and applied it to the bottom of the MC. This seems to work well. This week I also had the exhaust manifolds thermally coated, which should reduce the under hood temps.
I'm pretty happy with the Grenada/Corvette setup for the brakes. Even with the front power assist, the brakes require a firm foot. They are, however, consistent and reliable, and I haven't had any fade issues.
I really like the slightly lowered stance from the new spindles and Aerostar springs. I shimmed the lower bump stops and have not experienced any tire-rub. The spindle radius arms are at a different angle than stock, and interfere with the turn stops on the lower a-arm at full lock... this keeps me from getting the tightest possible turning circle. I could trim the turn stops with a grinder, but I haven't noticed any issue with the turning radius so I probably won't bother. I also don't like the idea of cutting on an otherwise stock a-arm. All of the other mods I've done to this car are reversible.
312T85Bird
Posted 13 Years Ago
Supercharged (461 reputation)Supercharged (461 reputation)Supercharged (461 reputation)Supercharged (461 reputation)Supercharged (461 reputation)Supercharged (461 reputation)Supercharged (461 reputation)Supercharged (461 reputation)Supercharged (461 reputation)
Posts: 162, Visits: 318
I have the same issue , However using DOT 5 works just fine. Tell the guy to make sure the original heat/drip shield is in place and use DOT 5 not the cheaper fluids.
312T85Bird
What?
Posted 13 Years Ago
Just a question re using DOT- 5 brake fluid? Is it compatible with #3 fluid? Or does the entire brake system need to be flushed first?
The Master Cylinder
Posted 13 Years Ago
Posts: 974, Visits: 6.2K
Paul Dot 5.1 is compatible with Dot 3 and 4. Dot 5 is silicone based and not compatible. So yes if using Dot 5 you need to flush the system.
312T85Bird
Posted 13 Years Ago
I installed a dual Master Cylinder on our '57 Bird the part # is M73323 and I use DOT 5 brake fluid with no problems, This Master was recommended by Hill's at the time and I am very satisfied as it will stop as good as disc brakes the first time but since there are no longer good quality shoes out there they will smell terrible and fade the second time you hit them hard until they cool off, but work great under normal conditions. No heat problems with the master cylinder with DOT 5 fluid.
312T85Bird
What?
312T85Bird
Posted 13 Years Ago
Sadly I cannot find my research papers, however what I did learn is that on a '57 Thunderbird you need to buy a kit like Hill's sells because of the 14" wheels unless you are not staying stock as we are then you can use 15" wheels and any number of components and the '70 Torino spindles do not need to be modified and you use a GM product caliper. I dug around for months on the inter net and finally found a guy that sent me the listing for the parts needed, he sells a conversion plate (For Caliper mounting) to stock spindles but also makes up kits for conversion so dig alittle and maybe someone else kept their files? I will keep digging thru my pile of stuff to see if I can find my records, the one thing that I kept in my file on our car is the number of the master cylinder that comes in the Thunderbird conversion kit as I was able to find that info seperately and added the Master cylinder (DUAL) and staying with drum brakes(It now stops almost as well as disc. brakes) The number is M73323 with no proportion valve needed or M39495 if larger reservoirs are desired, and I use DOT 5 fluid and have no heat issues with the fluid even after being in a Parade where the engine temp almost spiked. Out on the Rural Roads when having to panic stop due to a deer attempting to cross the road it does the job. One minor modification is to move the battery heat shield within 3/8" of the battery to allow for the best (Tight) bend in the new brake lines. All that said, almost any conversion can be done for about $350.00 if you have a reasonable parts supplier and the Bird kit for 14" wheels on a '57 runs about 12 to 1400.
312T85Bird
What?
312T85Bird
Posted 13 Years Ago
Using DOT 5 brake fluid and the standsrd drip shield (Some refer to this as a "Heat Shield") I have no problem using a dual master cylinder on Our '57 Bird. I still run stock drum brakes and as Terry Shay and the Bird guys in Dearborn had told me that it would, it performs as well as disc for quick stops providing that you are not constantly on them because then you will still get some fade (And smell with today's asbestos free shoes) and then we all know that they are not the best if driving thru puddles (But who would, right?) All that just to say "Use DOT 5 Fluid.
312T85Bird
What?
Tom Compton
Supercharged (311 reputation)Supercharged (311 reputation)Supercharged (311 reputation)Supercharged (311 reputation)Supercharged (311 reputation)Supercharged (311 reputation)Supercharged (311 reputation)Supercharged (311 reputation)Supercharged (311 reputation)
Posts: 287, Visits: 4.0K
Got disc brake kit for my 56 Victoria from Scarebird.  Easy install.
You gotta have the right tools and know how to use 'em.
TC - Austin, Texas
