Wanted: 292 Y Block Rocker Studs and Bolts (Unmodding Aux. Oiler)
Posted By '59Edsel 13 Years Ago
Posted 13 Years Ago
Thankfully nobody else here suffers from this!!Blink
'59Edsel
Posted 13 Years Ago
Supercharged (422 reputation)Supercharged (422 reputation)Supercharged (422 reputation)Supercharged (422 reputation)Supercharged (422 reputation)Supercharged (422 reputation)Supercharged (422 reputation)Supercharged (422 reputation)Supercharged (422 reputation)
Posts: 163, Visits: 3.5K
carl (5/12/2013)
'59Edsel (5/12/2013)
Hey guys, I am still in need of two (2) rocker bolts, as the ones taken out of the oilers are a bit too long. Here is a pic of the original and the one taken out.
They are not special bolts,just go to a hardware or home improvement store and get them. Ask for grade 5 bolts, or use a cutoff wheel on your dremel tool and cut 1/4 "off of what you have. It looks like there should be enough threads left.
Thank you for the advice. I will definitely do this if I cannot get originals. Forgive me, I am just very anal and have a touch of OCD.
http://oi43.tinypic.com/vyxn49.jpg
carl
Posted 13 Years Ago
Posts: 1.2K, Visits: 20.6K
'59Edsel
Posted 13 Years Ago
http://oi42.tinypic.com/eitjpt.jpg
carl
Posted 13 Years Ago
Send me a pm with your address and i will send you what you need Carl
'59Edsel
Posted 13 Years Ago
Hello, I am looking for the correct bolt and studs to correct the auxiliary oiler that was added to my 292. I need both sides. Here is a quote from charliemccraney from my other thread about what it is I need to do:
charliemccraney (4/23/2013)
The tubes are already installed in the correct location.
The yellowish blocks will need to be removed. A shorter bolt and appropriately sized stud may be required. A hole will probably need to be plugged since oil doesn't normally flow through that end of the shaft.
And photos:
http://oi48.tinypic.com/dce8pi.jpg
http://oi48.tinypic.com/2d1s39x.jpg
I am also in need of the rocker cover bolts, as two were removed to install the oiler kit.
