Wanted: 292 Y Block Rocker Studs and Bolts (Unmodding Aux. Oiler)
http://forums.y-blocksforever.com/Topic81954.aspx
By '59Edsel - 13 Years Ago
Hello, I am looking for the correct bolt and studs to correct the auxiliary oiler that was added to my 292. I need both sides. Here is a quote from charliemccraney from my other thread about what it is I need to do:
charliemccraney (4/23/2013)
The tubes are already installed in the correct location.
The yellowish blocks will need to be removed. A shorter bolt and appropriately sized stud may be required. A hole will probably need to be plugged since oil doesn't normally flow through that end of the shaft.
And photos:
http://oi48.tinypic.com/dce8pi.jpg
http://oi48.tinypic.com/2d1s39x.jpg
I am also in need of the rocker cover bolts, as two were removed to install the oiler kit.
By carl - 13 Years Ago
Send me a pm with your address and i will send you what you need Carl
Hey guys, I am still in need of two (2) rocker bolts, as the ones taken out of the oilers are a bit too long. Here is a pic of the original and the one taken out.
http://oi42.tinypic.com/eitjpt.jpg
'59Edsel (5/12/2013)
They are not special bolts,just go to a hardware or home improvement store and get them. Ask for grade 5 bolts, or use a cutoff wheel on your dremel tool and cut 1/4 "off of what you have. It looks like there should be enough threads left.
carl (5/12/2013)
Thank you for the advice. I will definitely do this if I cannot get originals. Forgive me, I am just very anal and have a touch of OCD.
By pegleg - 13 Years Ago
Thankfully nobody else here suffers from this!!Blink
