FOR SALE: ECZ-9425-b INTAKE Manifold, Plenum Divider removed and ported.
Posted By crazy56f100 13 Years Ago
FOR SALE: ECZ-9425-b INTAKE Manifold, Plenum Divider removed and...
crazy56f100
Posted 13 Years Ago
Normally aspirated (42 reputation)Normally aspirated (42 reputation)Normally aspirated (42 reputation)Normally aspirated (42 reputation)Normally aspirated (42 reputation)Normally aspirated (42 reputation)Normally aspirated (42 reputation)Normally aspirated (42 reputation)Normally aspirated (42 reputation)
Posts: 19, Visits: 107
I know it was a bad idea, but runs great at high rpmsBigGrin, ran as daily driver for two years on a built 292 with a isky cam, but i use the f100 for towing and not having the divider did affect the lower rpms, i dont plan to put it back on so figured someone my want it, i know what they go for untouched, but since it has been worked on i am not sure, so shoot a offer, i will get some pics posted soon.
Posted 13 Years Ago
Who did the porting?
crazy56f100
Posted 13 Years Ago
Lancer
Posted 13 Years Ago
Supercharged (502 reputation)Supercharged (502 reputation)Supercharged (502 reputation)Supercharged (502 reputation)Supercharged (502 reputation)Supercharged (502 reputation)Supercharged (502 reputation)Supercharged (502 reputation)Supercharged (502 reputation)
Posts: 203, Visits: 618
Still available??
www.speednchrome.com
Facebook
Instagram
Posted 13 Years Ago
If you still have it, fab a steel plate to fit back in it & weld it in, using a nickel or cast rod of some sort. Pre heat moderately & use short intermittent welds.. Cool it slow. You don't have much to lose, as is, it's mostly useless..
Posted 13 Years Ago
Last Active: 11 hours ago
Posts: 7.6K, Visits: 206.1K
This intake still makes a good base for a supercharger manifold. Simply fab a plate that bolts to the carb flange and then bolt the blower to the plate.
Lancer
Posted 13 Years Ago
I'm building a race motor and this would fit perfectly the way it is. Please let me know if this is still for sale.
Facebook
Instagram
