T-85 Borg transmission w/overdrive
Posted By 312T85Bird 13 Years Ago
Posted 13 Years Ago
Posts: 3.7K, Visits: 323.8K
I found mine last year at my local farm supply store. Came in a 2 1/2 gallon plastic jug in their house brand. Don't remember the price, but it wasn't much more than a jug of their house brand motor oil. GL 1 rated.
slumlord444
Posted 13 Years Ago
Posts: 1.2K, Visits: 137.8K
Used plain old 90 w gear lube in mine for years and it was still fine when I finaly pulled it out. Not to say that it would not have eventualy failed.
56ranchwgn
Posted 13 Years Ago
Posts: 8, Visits: 3.2K
The BW overdrive manual recommends straight 40w non detergent motor oil.
Joe 5bird7
Posted 13 Years Ago
Supercharged (112 reputation)Supercharged (112 reputation)Supercharged (112 reputation)Supercharged (112 reputation)Supercharged (112 reputation)Supercharged (112 reputation)Supercharged (112 reputation)Supercharged (112 reputation)Supercharged (112 reputation)
Posts: 67, Visits: 2.8K
For more than 40 yrs I've used SAE 90 in my Tbird T-85 with od. I've worn out a couple engines, but have had no issues with the trans. Out of curiosity I checked the manual for 57 Ford and T-bird and it says to use SAE 80 for manual trans, including overdrive.
312T85Bird
Posted 13 Years Ago
Supercharged (461 reputation)Supercharged (461 reputation)Supercharged (461 reputation)Supercharged (461 reputation)Supercharged (461 reputation)Supercharged (461 reputation)Supercharged (461 reputation)Supercharged (461 reputation)Supercharged (461 reputation)
Posts: 162, Visits: 318
I am not computer literate enough or I would scan and post the Warner Gear Company manual Especially the DARK PRINT IN LARGER LETTERS about what lubricants to use and not use and then if someone still wants to run what they prefer fine but at least all would know what the actual mfg. of the overdrive and not the car mfg. recommends. Sorta like car mfg's. and Tire mfg's., where the car mfg. wants low pressure for a soft ride not caring about the tire life, etc. and the tire mfg. puts the correct pressure requirement on the side of the tire. I have heard guys say that they have never run more then 25 pounds of air in their tires and never had a problem. Really?
Tom
What?
Glen Henderson
Posted 13 Years Ago
Posts: 1.4K, Visits: 7.5K
Interesting info here, I don't have any experience with the T85/R11, but I just recently acquired one in the 53 F100 that I am working on. It is aperaently from a later ford car and not a truck. It has find splines and a rear mount on the tailhousing. The overdrive unit has R11 cast into the housing. It looks pretty good except two of the case ears are broken off, I wonder if like John said (longer imput shaft) and someone tried to bolt it down tight. The engine in the old truck was orginal 6 cyl. No matter since this truck is for my wife, or so she says, it is getting a FMX conversion.
Glen Henderson
Freedom is not Free
Letohatchee, AL
Posted 13 Years Ago
I'm laughin', Tom...
Even today, any corner lot used car dealer that hasn't adjusted his vehicles' tire pressures lower than the vehicle manufacturer's recommendation likely hasn't been in business long...
Oldmics
Whistling Posted 13 Years Ago
Posts: 710, Visits: 78.1K
I just changed out the fall air to the winter air in all of my vehicles tires.
All run much smoother now.
Oldmics
Posted 13 Years Ago
With the cost for air at the corner gas station these days, I hope that you have your own compressor, Oldmics.
Changing the air for the winter is probably a good idea. Moisture in the summer air could cause icing inside the tire.
LOL. -You can tell I've been up too long today!
312T85Bird
Posted 13 Years Ago
The fine spline T-85 that I have from a '58 FORD with a FE 352 and from a '57 FORD Y 312 have the same length input shafts and will inter change merely by changing the clutch disc. I thing some one may have forced a trans into too small of a pilot bushing?
Tom
What?
