Visits: 3.4K
Since my 55 is converted to 12 volts I am thinking about installing a 56 battery tray to get a larger battery then I have with the Honda civic size battery I have in the 55 tray,I will need everything including the bracket that is spot welded on the inner fender.
Visits: 3.4K
Got the tray and bracket but still need the hold down parts
Visits: 32.6K
Dennis Carpenter.I didn't have a problem with the quality and fit of this item.Most used hold down brackets are corroded from Battery acid.He sells the holdown bracket as well as bolts and washers etc.
