Since my 55 is converted to 12 volts I am thinking about installing a 56 battery tray to get a larger battery then I have with the Honda civic size battery I have in the 55 tray,I will need everything including the bracket that is spot welded on the inner fender.
Got the tray and bracket but still need the hold down parts
By oldcarmark - 12 Years Ago
Dennis Carpenter.I didn't have a problem with the quality and fit of this item.Most used hold down brackets are corroded from Battery acid.He sells the holdown bracket as well as bolts and washers etc.
