T-bird Overheating in Traffic... What would YOU do?
Posted By skygazer 13 Years Ago
312T85Bird
Posted 13 Years Ago
Supercharged (461 reputation)Supercharged (461 reputation)Supercharged (461 reputation)Supercharged (461 reputation)Supercharged (461 reputation)Supercharged (461 reputation)Supercharged (461 reputation)Supercharged (461 reputation)Supercharged (461 reputation)
Posts: 162, Visits: 318
Before removing the 1" spacer, put a stainless steel restrictor plate between the spacer and the timing cover housing, this plate can be purchased from Hill's Thunderbird Center and others.
312T85Bird
What?
lyonroad
Posted 13 Years Ago
Posts: 703, Visits: 3.1K
312T tell us more about this restrictor plate. How does it work and is it only used on T birds? Thanks.
Mark
1956 Mercury M100
1955 Ford Fairlane Club Sedan
Delta, British Columbia
GREENBIRD56
Posted 13 Years Ago
Posts: 1.7K, Visits: 102.7K
On Thunderbirds there is a open spacer between the water pump and front cover - moves the pump forward toward the radiator about an inch or so. The spacer creates a huge space behind the impeller - makes it spin in a large very open cavity. Destroys any hope of pump efficiency - in my opinion. There is available a stainless baffle that sandwiches between the impeller and the open cavity to try and cut down on the volume of the swept space. Seems a reasonable idea.....
Accounts vary on whether it works or not. CASCO (t-bird parts supplier) has run a test you can find on their site - and the test shows the baffle failed to solve any problems. They got better results by (1) using a free(er) flowing thermostat and further (2) by using a modified pump impeller that sweeps more of the opening in the spacer.
Baffle didn't do anything for my outfit at all - waste of labor and gaskets. By comparison, the larger flow volume thermostat showed a change for the better on my infrared temp gun right away. It also helped instantly to put an orfice in the bypass tube between the manifold outlet and the pump. Cuts down on a huge "short circuit" that allows for quick warm-ups - but then never ceases to re-circulate the max temp hot water.
Posted 13 Years Ago
Steve, Based on the fact that the pump works by drawing water out of the rad by centrifugal force, one has to wonder how restricting the output side with the plate would help flow? I got better results on my pumps by closing down the impeller to body tolerances than any other "trick".
However to cloud the issue, John Mummert felt like the plate worked! I don't have a 'Bird so I really don't have anything to experiment on. I do kinda think that Doug thrasher's got a point with the radiator comments, and a fan shield has to help.
