y/block carb adaptor plate
Posted By yblock32deuce 13 Years Ago
yblock32deuce
Posted 13 Years Ago
Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)
Posts: 173, Visits: 1.5K
does anyone know ,or have , where i can buy one of those adaptor plates to put a newer carb on a small port manifold? having trouble with a 56 lincoln carb ? thanks
speedpro56
Posted 13 Years Ago
Posts: 1.3K, Visits: 9.2K
Be sure to change the distributor to a 57 and later if you have'nt already.
-Gary Burnette-
Posted 13 Years Ago
Posts: 6.1K, Visits: 442.6K
Speedway Motors have a lot of adapters.
Posted 13 Years Ago
Last Active: 1 hour ago
Posts: 3.6K, Visits: 497.7K
Summitt or Jegs
Posted 13 Years Ago
Posts: 7.4K, Visits: 205.7K
Here’s a link for you.
Vintage Speed small to big carb adapter
Rono
Posted 13 Years Ago
Posts: 1.3K, Visits: 80.0K
TransDapt also makes carb adapter plates.
Rono
yblock32deuce
Posted 13 Years Ago
thanks everyone for the help.Smile
Mike1956
Posted 13 Years Ago
Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)Hitting on all eight cylinders (8 reputation)
Posts: 6, Visits: 275
Whats the deal with the 57 dist? Vacuum?
1956 Customline
Posted 13 Years Ago
Posts: 4.6K, Visits: 38.2K
The earlier dual vacum loadamatic are junk for tuning purposes. Especialy if you change to a later type carb. Most people are suprized at the difference it makes by changing the distributor alone. Do a search for loadamatic and you will find a LOT of interesting reading on the subject. Chuck
Posted 13 Years Ago
Chuck: If I understand the original post correctly, he's not using a later carb.. it's a 56 Lincoln carb..
