y/block carb adaptor plate
http://forums.y-blocksforever.com/Topic76919.aspx
By yblock32deuce - 13 Years Ago
does anyone know ,or have , where i can buy one of those adaptor plates to put a newer carb on a small port manifold? having trouble with a 56 lincoln carb ? thanks
By speedpro56 - 13 Years Ago
Be sure to change the distributor to a 57 and later if you have'nt already.
Speedway Motors have a lot of adapters.
By paul2748 - 13 Years Ago
Summitt or Jegs
By Ted - 13 Years Ago
Here’s a link for you.
Vintage Speed small to big carb adapter
By Rono - 13 Years Ago
TransDapt also makes carb adapter plates.
Rono
thanks everyone for the help.Smile
By Mike1956 - 13 Years Ago
Whats the deal with the 57 dist? Vacuum?
By MoonShadow - 13 Years Ago
The earlier dual vacum loadamatic are junk for tuning purposes. Especialy if you change to a later type carb. Most people are suprized at the difference it makes by changing the distributor alone. Do a search for loadamatic and you will find a LOT of interesting reading on the subject. Chuck
By PF Arcand - 13 Years Ago
Chuck: If I understand the original post correctly, he's not using a later carb.. it's a 56 Lincoln carb..
Ah! re read his post.. I may stand corrected on which carb..
The lincoln carb should fit without an adaptor if it is of the small bolt pattern. but he said a new carb be it lincoln or whatever and that could mean for a later year for which he would need an adaptor plate. Maybe a futher explaination of what year intake and year the new carb is for could help???
By 55fordf100 - 13 Years Ago
go to reds headers site go under the yblock and they have one i believe
