Aerostar springs...AGAIN
Posted By stlroken 14 Years Ago
dbird
Posted 13 Years Ago
Posts: 279, Visits: 4.0K
Only took me ten months.Brought this old thread back to life as I finally got around to the hijacked topic. Taking my time I spent two days on less than a days worth of work, but managed to move the body 5/16 to 3/8 inch at the back bumper. Really, easier than expected. Thanks to all that contributed for the input.
I'm really looking forward to not having to use the air shocks to keep the tires from rubbing.
Don
Oh, and in the meantime I did put Aerostar springs on and like the way it sits with stock spindles.
bird55
Posted 13 Years Ago
Posts: 1.1K, Visits: 58.8K
i think it went a quarter inch
glrbird
Posted 13 Years Ago
Posts: 616, Visits: 7.1K
Thanks Alan, just one question, how much did you need to move yours?
Gary Ryan San Antonio.TX.
bird55
Posted 13 Years Ago
I rechecked the exhaust and was wrong about the size. They are 2". tailpipe. original was 1 7/8" i think. still very tight.
bird55
Posted 13 Years Ago
Yep, you have it right. Be patient with all of it. go slow. 4x4 might be overkill but I already had them. I have one area in the drivers side floor that is "soft". It's in the actual floor brace to body mount area. Not too worried about it I've been keeping an eye on it for about 40 years.w00thasn't seemed to get much worse and this is no show car.
The 2.25 exhaust requires modding the ex. fittings within the bumperettes, no big deal but very tight.
Yes, I did use lube on all the body bolts and cage nuts underneath, can't hurt.
dbird
Posted 13 Years Ago
Alan, thanks for the update, gets me a little more motivated. Let me see if I get it right, cut 4x4s to the length of the rockers, unbolt obviously, jack up until the mounts separate then lower again, then bump over? Did you lubricate between the cushions an whatever they separated from, I guessing some stuck to the body and some to the frame? I don't think I have to worry about the bumper, my exhaust looks pretty weak, but I really like to se what 2.25 exhaust looks like coming through the bumper.
Thanks again,
Don
bird55
Posted 13 Years Ago
Over the Christmas and new year break I was able to accomplish moving the body over and lowering it. Smile
I went ahead and removed the seat to have easy access to all the body bolts. I have a spec diagram if anyone wants it although it's pretty obvious where they are located.
I opted to completely remove all the bolts from the firewall back. I loosed the ones in front of the firewall.
I made some coat hanger gismos to stick in the holes so to not knock out the washers or body shims.
I used 2 large floor jacks with 4 x 4's between the rockers and frame rails. Then I lifted everything carefully to make sure it was loose and had broken the tension, then found it best to set it back down.
I also discovered I had to remove the rear bumper. The exhaust I have is 2 1/4 diam. , so there was not any give in that area. I also had to remove one ex. bracket near the axle.
I was able to move the body over by bouncing it over but it seemed like it wanted to spring back. That's when I took it off the Jacks. We also had begun to move the whole car over! so had the jimmy a rig to keep it from sliding. Just another contraption between the concrete block wall and the brake drum. It worked. I did have to ream out the bolt holes farthest back to get the bolts back in them.
A lot of stuff to do but it lined up finally. Then I was able to use some 1" aluminum lowering blocks I made to drop the rear. I could probably drop another 1" with room but I would need to get longer U bolts. I'll see how this works out.
Sorry for the long post but I hope it helps out someone else. I'll try to get some pictures up soon.
Almost forgot, I did use a bottle jack between the driver side rocker/dogleg and frame also. Be careful doing this I did it more to keep it from sliding back than trying to move. It just kept pressure on it.
BTW the doors and seams fit just as crummy as they always did so no worse. w00t
Vic Correnti
Posted 14 Years Ago
Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)
Posts: 347, Visits: 12.3K
I would keep a close eye on the fit at the doors while forcing things around birds do not have the support of a roof to keep things where they belong.
bird55
Posted 14 Years Ago
that make sense to me now how you used the bottle jack, easier on my back too! thanks.
I've wondered about the steering column and shift linkage but I guess those are non issues. Time to stop thinking about it and get it done.
Posted 14 Years Ago
Posts: 1.9K, Visits: 195.0K
Well, I'll take some of the blame for hijacking it, too. The plates the body bolts go into are made to "slip" a bit in the mount, and all I did was loosen the bolts, not remove them. One bolt in the trunk was an exception, that plate was stuck. I pulled the bolt, and with a punch and hammer, I broke it loose, end of problem. The right rear quarter on my car has been replaced (its got a 56 door jamb), and is not lined up quite right. I had enough room to move that the fuel and brake lines were not a problem for the 3/16" I needed. Once I remembered to loosen those two bolts, which I had marked and forgotten, it was a non event. Using the bottle jack sideways between the frame and 2x4 under the door was more a matter of going easy, slow and watching than necessity. If I was younger and had a good back, I could probably done it by just pushing or using a small lever. But after 50+ years, many of these cars are modified or poorly repaired, rusted, who knows. In the late 80's, mine went from a drug dealer to his attorney as a retainer, so you can imagine some of the repair work I've found.
