Doug T
Visits: 2.6K
The '56 shop manual has a complete listing of the original spring specifications. If I remember correctly the free height is about 14.5" and the compressed height is about 9.5" for all springs. The table of springs does not list what cars the various springs go into but the lowest spring rate is about 250#/" and that spring goes in T birds.
bird55
Posts: 1.1K,
Visits: 58.8K
Seems like this thread is all over the place, so here goes some more. I just wanted to say I just installed a Hotchkiss suspension kit on my Bird and it really made a gigantic difference in cornering and overall feel of the road. Bilstein shocks all around. I still plan to lower it more however It still has the the stock spec front 55 springs. I plan to replace them with the Aerostar soon and may use a drop cup for that and 1" blocks in back. I also USED to have a heavier front Station Wagon sway bar that I ran for 40 sumethin years. I had an extra leaf in the back that I removed and havent missed that at all! Much better! overall car height is the same as before but like I said needs to come down at least an inch. I'll get some pics up sometime soon.
The Master Cylinder
Visits: 6.2K
Alan, Yeah. I think I may have hijacked it a little.  Ok, The springs that I took out of my RanchWagon are 15.5" long extended. Here's a picture of how the tire sits in the well now.
texasmark1
Visits: 2.7K
Anyone done the Aerostar springs in their 57 Fairlane and willing to post info/pics? I want to do this to mine too! Mark
junkyardjeff
Visits: 3.4K
Will they settle too much with a Y block since its much heavier then the V6 that came in the van,in a couple years I will be putting a Y block back in my 55 and want to figure out what springs to use. Right now I have Fatmans dropped spindles but thinking about finding a disc brake kit that uses the original spindles.
MarkMontereyBay
Visits: 3.8K
Alan, could you post some info on the Hotchkis stuff. Is there a specific kit and part number? What parts did you install? I should be starting the Granada disc brake change soon, got the reamer from Speedway, so it might be good to get the Hotchkis stuff also if that fits my plan.
Thanks,
Mark
57 Black Tbird 312/auto
bird55
Posts: 1.1K,
Visits: 58.8K
I tried to reply earlier today Mark but the message vanished into cyber space. Here goes again. The Hotchkiss kit is available from Larrys TBirds in CA. pt #T18124A, T18125A. I don't have the install directions handy (at the Shop) but it's pretty straight forward. You can look at some similar setups online at the Hotchkiss site but I think you have to buy them from Larrys as I think they had them designed and made up as exclusive. 470 bucks not including shocks. Bilsteins are almost 100 per! but I like them. I did for some reason have to add extenders on the rears as they were too short. even after visiting with Larry's? No explanation? They work now.
MarkMontereyBay
Visits: 3.8K
Thanks Alan. Seems like Larry's Tbird needs some customer service tuning. As far as shocks fitting the early Birds, RockAuto is a good source to check on applications. For what it's worth:
KYB's fit rear:
Guide: KYB 343219 Shock Absorber
BRICKLIN SV-1 (1975 - 1976)
DAIHATSU ROCKY (1990 - 1992)
EDSEL CITATION 1958
EDSEL CORSAIR 1958
EDSEL PACER 1958
EDSEL RANGER 1958
FORD CUSTOM 1957
FORD FAIRLANE (1962 - 1970)
FORD FALCON (1960 - 1970)
FORD GALAXIE 1959
FORD MUSTANG (1964 - 1973)
FORD RANCHERO (1960 - 1965)
FORD THUNDERBIRD (1955 - 1957)
FORD TORINO (1968 - 1971)
JAGUAR MARK X (1962 - 1966)
MERCURY COLONY PARK (1957 - 1960)
MERCURY COMET (1960 - 1970)
MERCURY COUGAR (1967 - 1973)
MERCURY CYCLONE (1968 - 1971)
MERCURY MONTCLAIR (1959 - 1960)
MERCURY MONTEGO (1968 - 1971)
MERCURY MONTEREY (1959 - 1960)
SAAB 99 (1969 - 1978)
VOLVO 122 (1961 - 1968)
VOLVO 1800 (1961 - 1973)
and fronts fit
KYB Part # 343137 GR-2 / Excel-G
FORD MUSTANG II 1974
FORD PINTO (1971 - 1980)
MERCURY BOBCAT (1975 - 1980)
Please refer to catalog for application details.
Marc
Visits: 5.5K
I used early 90's blazer springs on my 57. Not quite as much of a drop as aerostar springs. Worked great, no problems with the stock shocks, sits and rides nice.
skygazer
Visits: 1.5K
Here's a shot of my '55 bird with aerostar springs, and 1.5" drop Granada spindles from Drop-n-stop. Rear springs are stock. Very satisfied with the ride & control. Front & rear 7/8" sway bars, KYB Gasadjust shocks.
