Aerostar springs...AGAIN
Posted By stlroken 14 Years Ago
bird55
Posted 14 Years Ago
Posts: 1.1K, Visits: 58.8K
For those of you that would want to see the Hothckiss sway bar kit instructions for the 55-57 Bird, I did find the missing pdf file and I can email it to you. I tried to upload to this site but it won't allow that size.
You could also just get it from Hothckiss at this point.
Posted 14 Years Ago
Master Cylinder. Can you take another picture showing the side of your car and just not the front wheel? Have you lowered/rasied the rear or is it stock and has it settled any...Thanks
The Master Cylinder
Posted 14 Years Ago
Posts: 974, Visits: 6.2K
Dry lakes, The rear has 2" lowering blocks. Unfortunately I can't get a side shot of the car right now. I have some other projects going on right now, I'm installing power windows and power remote door locks. The front seat is out to give me some room to work under the dash and cut holes in the door jams to run wiring.
See what I can do for a picture.
MarkMontereyBay
Posted 14 Years Ago
Posts: 733, Visits: 3.8K
Thanks Alan, I have been looking at the Hotchkis website. Got the info there. I am going to try a set of Aerostar front springs along with the Granada front disc brake conversion on my 57 Bird. I like the stance on Skygazer's. I had cut one coil out of the stock front springs long ago but after installing aluminum heads, intake and Sanderson headers the front end came up significantly from the weight reduction. Don't know if I can get away with this setup with the 225-60 series Michelins and 15x7 Torque Thrusts. May have to be more careful on turning bumps and front fender clearance.
57 Black Tbird 312/auto
Posted 14 Years Ago
Posts: 1.9K, Visits: 195.0K
Based on my car, with the Aerostar springs, 225 60 15, 3.5" backspace, I think you'll be ok even with the Granada spindles. I've got power everything, and a/c, so the wieght is probably above average in front.
MarkMontereyBay
Posted 14 Years Ago
Thanks for that Miker. I keep saying I am going to start the Granada disc thing, have all the parts ready but been waiting for the weather to turn truly winter. It rained for a couple days last week then back to 90 degrees, it's kind of crazy weather here. Don't want to miss out on some excellent beach cruising if it is still warm and clear. Supposed to turn wet again next week so after a full load of Tday dinner maybe my Black Friday will be to pull the brakes apart.
bird55
Posted 14 Years Ago
I finally got around to installing the AeroStar springs yesterday. The front end dropped 2 inches. With stock spindles, ride is good Hotchkiss front sway bar and Bilstein shocks. Still road testing to make sure it's where I want it.
The back end is another story-I have to loosen the body mounts and skoot the body over to equalize tire clearance in back. fronts are 17x7 with 215/50R17 backs 17x8 with 255/50R17. Rearend is a new narrowed 9" with 3.50 trac lok and a Hotchkis four link. All the wheels are 0 backspace, and the backs just barely fit but moving the body over it will be just right. And then lower 1-2"s in back. Made one of those handy tools to pop open the ball joint from the spindle and it made the job a lot easier. Smile Have to get better pics soon.
MarkMontereyBay
Posted 14 Years Ago
Alan,
That looks great. I think when you lower the back the front will come up a little. I started the Granada change but got waylaid replacing the water pump on the 65 Galaxie (352 with factory A/C). I ordered Aerostar springs form Rockauto on Thursday morning and were delivered Friday morning to my door. 53 bucks including shipping. I have thought about a narrowing the 57 9 inch rear end but too costly for now plus I am supposed to be getting the T-5 conversion going next.
Posted 14 Years Ago
Alan, the body shifts pretty easy, after you remember to loosen the two bolts behind the seat, as well as the rest of them. Don't ask how I know. The two inches you dropped also seems to confirm my old springs had been cut.
bird55
Posted 14 Years Ago
miker (12/11/2012)
yes, I am aware of those I count nine per side off the spec drawing I have. So, the seat has to come out but I figure I can just pull back the carpet on the remaining ones. Seems like a daunting task overall but everyone I've talked to said it is easy. Sounds like "Famous last words…" to me Tongue Also a lot of effort just to move the body over about 1/4 -to 3/16ths! But hey, I've dumber stuff. w00t
