Chromoly Pushrods
Posted By unibodyboy 14 Years Ago
unibodyboy
Posted 14 Years Ago
Supercharged (128 reputation)Supercharged (128 reputation)Supercharged (128 reputation)Supercharged (128 reputation)Supercharged (128 reputation)Supercharged (128 reputation)Supercharged (128 reputation)Supercharged (128 reputation)Supercharged (128 reputation)
Posts: 118, Visits: 2.4K
16 Smith Bros pushrods
-8.00" effective length.
-3/16 radius cup & ball
-5/16 x .049 4130 Chromoly Non-Heat Treated tube
Brand new. $80 plus shipping from 99163.
My name is Greg and I am addicted to Y's.
Richard
Posted 14 Years Ago
Supercharged (932 reputation)Supercharged (932 reputation)Supercharged (932 reputation)Supercharged (932 reputation)Supercharged (932 reputation)Supercharged (932 reputation)Supercharged (932 reputation)Supercharged (932 reputation)Supercharged (932 reputation)
Last Active: 5 Months Ago
Posts: 410, Visits: 81.0K
Are these a direct replacement for a 312 motor.
unibodyboy
Posted 14 Years Ago
The ball and cup size (3/16 radius) and tube size (5/16) are correct. The effective length varies depending on a number of factors. You can easily measure the effective length if need be.
unibodyboy
Posted 14 Years Ago
Bump, thanks for looking.
Ghsthrss
Posted 14 Years Ago
Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)
Posts: 33, Visits: 602
Would said push-rods fit a 292 and would they be better than my brand new stock ones, ie. will it make the truck go faster?
Spending my children's inheritance one Y Block at a time.
Posted 14 Years Ago
Unfortunately, pushrod length on a y-block is not simply a matter of the engine displacement size.
What Greg was referring to is that different year FoMoCo y-block cylinder heads in combination with different ratio rockerarms (1.54 or 1.43 to 1) result in two (?) different common pushrod lengths for y-block engines.
Google 'John Mummert' and review the pushrod offerings on his web site for more information on this.
The tubular pushrods are desirable for reliability purposes only. They will not increase horsepower.
Hope this helps! Smile
Regards,
Ghsthrss
Posted 14 Years Ago
Im running ECZ-G heads, with 1:54 rocker arms on a 292?? I'll go check the bible (John Mummert)
edit: Just got off the phone with "John", these, by what i understood are for the 1:54 ratio rocker arms. He stocks em for $75.00
John Mummert
Posted 14 Years Ago
Posts: 919, Visits: 7.5K
I have never seen any evidence that rocker arm ratio of 1.43 or 1.54 affects p/r length. The 75.00 pushrods are mild steel.
What he is selling in this ad are chromoly pushrods and sell for 130.00.
They could increase performance if you are using a lot of spring pressure, say 300# open and running to high RPM. The mild steel pushrods would likely flex under they conditions.
He says they are 8.00" effective length. Add .187" for overall length.
That means they should work with 56-59 heads.
http://ford-y-block.com
Posted 14 Years Ago
Greg: Did I get your zip correct, you're in Pullman Washington? Will you mail to B.C. ? (to near Vancouver)
Ghsthrss
Posted 14 Years Ago
So you got the payment, I can assume that the push rods are being sent? I was not able to email you privately because it says you had exceeded your limit... any problems i should know about?
