Camshaft Fuel Pump Components
Posted By Rono 13 Years Ago
Rono
Posted 13 Years Ago
Posts: 1.3K, Visits: 80.0K
I'm just wondering about the necessity of the counterweight behind the fuel pump eccentric. The Eickman book seems to suggest that the counterweight was used in early Y-Blocks, but dropped in later years(?). Since this is a  C2AE block with a Rollmaster timing chain, should I use it or not? I can't see how it could hurt anything by having it in there.BigGrin
Thanks,
Rono
Oldmics
Posted 13 Years Ago
Posts: 710, Visits: 78.1K
I would think it aids in camshaft balancing issues.
If you dont use it-send it my way. BigGrin
Lets see what the experts have to say.
Oldmics
The Master Cylinder
Posted 13 Years Ago
Posts: 974, Visits: 6.2K
Ron, I leave it in, otherwise you will have to find a spacer of equal thickness, would you not?? Just my 1¢.
But I'm not an expert...
Posted 13 Years Ago
Last Active: 8 hours ago
Posts: 7.4K, Visits: 205.6K
Rono.  If you have the fuel pump counterbalance plate, then by all means use it in conjunction with the fuel pump concentric.  I’ve checked the balance of the camshafts with and without that particular plate, and it does remove a significant amount of imbalance in the cam timing area simply by using it.  It was discontinued during 1956 as one of many cost cutting measures on the Y’s  but was brought back for a short period of time on the High Performance 289’s.
Rono
Posted 13 Years Ago
Thanks Ted and everyone else...the "Aye's" have it. I'll keep the counterbalance plate.Tongue
Rono
