Oil pickup tube mod.
Posted By sd56effie 14 Years Ago
sd56effie
Posted 14 Years Ago
Hitting on all eight cylinders (23 reputation)Hitting on all eight cylinders (23 reputation)Hitting on all eight cylinders (23 reputation)Hitting on all eight cylinders (23 reputation)Hitting on all eight cylinders (23 reputation)Hitting on all eight cylinders (23 reputation)Hitting on all eight cylinders (23 reputation)Hitting on all eight cylinders (23 reputation)Hitting on all eight cylinders (23 reputation)
Posts: 19, Visits: 292
Hey guys so Im just abound done modifying my oil pan to clear my rack and cross member. Now its time to drop my oil pickup tube about two inches. Does anyone have any experience with this? Any idea's about how to do it? thanks in advance.
Dustin
1956 F-100 in the works.
Posted 14 Years Ago
Last Active: 1 hour ago
Posts: 4.6K, Visits: 39.3K
Maybe just find some tubing that will slip over the existing pickup tube cut a new section long enough to lower the pickup the 2" and over lap at each end and weld, or solder, it in. Thats my 3cents. Chuck
slumlord444
Posted 14 Years Ago
Posts: 1.2K, Visits: 137.8K
I braized mine when I had to repair it years back when the original engine put a rod through the side of the block and took out the pan and the pick up tube. May have used a copper pipe union as I recall.
lyonroad
Posted 14 Years Ago
Posts: 703, Visits: 3.1K
My first oil pan had a mangled oil tube and I found out that the tube is almost exactly the same size as regular copper pipe. Maybe you can use a couple of couplers and a piece of copper pipe. You might consider silver solder. That is what was recommended to me. As I recall there isn't much straight tube in the down piece that you need to extend. Perhaps you can get a chunk of the soft copper tube and pre bend a slight curve before you install it. In my case I found another pan with a good tube so I never did try to fix the wrecked one.
Mark
1956 Mercury M100
1955 Ford Fairlane Club Sedan
Delta, British Columbia
sd56effie
Posted 14 Years Ago
thanks for the advice guys, i ended up using a piece of 1/16 wall 3/4 pipe. cut about two inches off the pipe and cut the pick up tube just above the pickup element. welded it and its done. here are a few pics
Posted 14 Years Ago
Here are pics of a couple more options for hooking up the oil pump inlet tube to the sump.
