Visits: 1.1K
I was wondering if anyone hear does or knows someone that will do port work on y-block heads. It is on my turbocharged y-block build. Engine is getting new heads with bigger valves and dished piston for lower compression and a better boosted burn. I would like to get these heads ported if anyone out there know someone I would really appreciate a number or name. Thankyou.
Last Active: 20 minutes ago
Visits: 38.5K
Try John Mummert or Ted Eaton. They both are listed in the links page. Chuck
Posts: 1.0K,
Visits: 3.8K
You can do it by yourself also. With boost it's not so critical to have ports as fine as with non boosted engines. Just make the exhaust ports big as possible and clean the bowls and widen up the area under the valve. Tim has done several beautifully shaped exhaust ports. Intake ports you can only clean up to match the intake gasket openings. There is several topics about porting too... http://www.y-blocksforever.com/forums/Topic66122-3-1.aspx?Highlight=port http://www.y-blocksforever.com/forums/Topic46226-3-2.aspx?Highlight=porting+heads
