Need Dual Crank Pulley
Posted By fabieber Original '55... 13 Years Ago
Posted 13 Years Ago
Posts: 19, Visits: 34
Anyone have a dual pulley that will fit my 292 so I can add a power steering pump.  I have little to no knowledge of what I need so help in buying the correct part would be a blessing to me.
Thanks as always,
Fred
Posted 13 Years Ago
Fred: Link over to John Mummert's site www. Ford-Y-block.com There may be help there
John Mummert
Posted 13 Years Ago
Last Active: 2 Weeks Ago
Posts: 916, Visits: 7.5K
Fred, if you are using the original crank pulley for the high mounted fan there is no way that I know of to add a crank pulley groove.
The 54 and 55 trucks are a real problem.
The only way I know of is to switch to a 56-later style water pump and crank damper then you can add pulleys to the crank damper.
You will also need a 56-64 truck pump pulley and fan.
if you have a fan shroud it probably won't fit with the fan mounted directly mounted on the water pump. You will need a 56 truck shroud if you want to use one.
http://ford-y-block.com
Posted 13 Years Ago
Thank you for the clarification.  I will look closely at my situation and contact you directly.
Fred
