aussiebill
Posts: 1.8K,
Visits: 11.4K
Maybe you guys may know a scource for 256 non vacuum fuel pump? i know they are hard to find but you may be able to give me a lead. thank you, regards bill.
314
Visits: 1.7K
if its a 55 any y pump will fit.your block should have special mains with 3 in bolts.
aussiebill
Posts: 1.8K,
Visits: 11.4K
314 (3/16/2012) if its a 55 any y pump will fit.your block should have special mains with 3 in bolts.Thanks for reply, but dont think thats right.
pintoplumber
Posts: 1.0K,
Visits: 163.9K
If it's like the 239, an Airtex 4070 is what I use.
Dennis in Lititz PA
314
Visits: 1.7K
a fellow gave me one of these blocks about 15 years ago.untill then i thought 55 trucks were 272.these were CEBY blocks.they were the only true truck blocks,that is the only ones that were different than car blocks.there was a ceby car block as well but it didnt have special mains just heavy trucks.the caps were 1/8 inch higher with 3 in bolts.i could see no difference in the fuel pump.these blocks were used to make 272s as well.
marvh
Visits: 16.7K
Bill: Does the pump look like this. According to my Carter pump book the 55 F600 with a 256 engine takes a M3150 pump which is the HD model for the Carter M3528 The 279 engine took a M3022 pump . marv
lyonroad
Visits: 3.1K
Just a note regarding the CEBY blocks. I have one of those and it came in my '56 Mercury M100. According to John Mummert's chart it is a cast in Canada Export block. 256-272. Thanks
Mark
aussiebill
Posts: 1.8K,
Visits: 11.4K
pintoplumber (3/17/2012) If it's like the 239, an Airtex 4070 is what I use.Dennis, marv, thanks, i,m trying to ascertain if the 239 was same as 256 pump, and hence different to 272/292/312/, i am trying to find out for person over here. i think the 239 pump has straight arm? but not too sure. regards bill.
pintoplumber
Posts: 1.0K,
Visits: 163.9K
239 has a straight arm. If you google airtex 4070, you can see a picture of it .
Dennis in Lititz PA
old cars
Visits: 1.3K
Hello there,I have a 256 in my 54 mercury and I put a 73 ford 360 on mine and it works great.... my wipers not so good
