PVC question.
Posted By uncleaud1 14 Years Ago
uncleaud1
Posted 14 Years Ago
Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)
Posts: 5, Visits: 17
This is basic auto 101 I know but I can't remember back that far anymore. I'm replacing the draft tube on my tbird with the pvc kit that everyone supplies and tonight while I was putting it on, for the life of me I couldn't see why it wouldn't be just a large vacuum leak with the vented oil cap and all. What am I missing. Sorry for the elementary nature of this.
Riz
Posted 14 Years Ago
Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)
Posts: 177, Visits: 4.4K
No worries about questions--i am by no means an expert ,but after some recent PCV woes i leaned quite a bit.
The PCV is meant to maintain equilibrium between the intake and the crankcase and return unburnt fuel vapor to the intake to be reburnt. It serves as an early emissions reducer, gas mileage enhancement and also to keep the corrosive vapors out of the engine. It is really only supposed to open one way when there is a pressure imbalance when the crankcase pressure is too high it bleeds it off.
When doing PCV retrofits just make sure you get the right valve direction depending on if you are fitting the valve in the valley cover or the manifold port. The wrong one will result in a vacuum leak. Or a malfunctioning or stuck valve will result in a vacuum leak as well.
Mike Rizzo
1963 F100 "Rudy"
Daniel Island, SC
Posted 14 Years Ago
Here are some past threads on PCV valves.
Blocking off the road draft tu...
Crankcase evacuation
Finned valley pan and PCV valv...
Installation of PCVvalve into the top of the block
Installation of PCV valve at t...
Modifying valve covers for PCV...
Valley pan PCV valve installat...
Valve cover baffle for PCV val...
Why a PCV valve or system?
