Ignition switch bezel tool wanted
Posted By ronsplace 13 Years Ago
ronsplace
Posted 13 Years Ago
Supercharged (350 reputation)Supercharged (350 reputation)Supercharged (350 reputation)Supercharged (350 reputation)Supercharged (350 reputation)Supercharged (350 reputation)Supercharged (350 reputation)Supercharged (350 reputation)Supercharged (350 reputation)
Posts: 157, Visits: 630
Where can I buy the small tool I need to removed the ignition switch bezel on my 1956 Ford Fairlane?  I couldn't find it in the Dennis Carpenter online catalog.  Thanks, Ron
slumlord444
Posted 13 Years Ago
Posts: 1.2K, Visits: 137.4K
Any of the T-Bird parts guys have them.
Posted 13 Years Ago
What worked on my 57 was a small pair of flat end Snap Ring Pliers.
bird55
Posted 13 Years Ago
Posts: 1.1K, Visits: 58.8K
Yes what Paul said or notch down the end of a small piece of pipe that fits.
James Tone
Posted 13 Years Ago
First Time Poster
First Time Poster (1 reputation)First Time Poster (1 reputation)First Time Poster (1 reputation)First Time Poster (1 reputation)First Time Poster (1 reputation)First Time Poster (1 reputation)First Time Poster (1 reputation)First Time Poster (1 reputation)First Time Poster (1 reputation)
Posts: 1, Visits: 5
I bought one from Larry's. It has a tool on each end.  One for the light switch (others too) and the one for the ignition. Grabbed it with vicegrips to make it easy to use.
I just changed out my ignition switch. Bought a replacement made by Standard Parts at a local parts store. "Appeared" to be the same but not true. After much difficulty trying to get front bezel in I took all the wires off again and really looked at the original and the new one. After close examination they were not idenitical but with a small grinder I was able to remove a small section of the new one and it worked fine off the car. Putting it in the car was another story. No matter how hard I pushed in on the spring I could not get the bezel nut to go on. Finally I slightly chamfered the 2 tabs on the bezel and it went right together. The lock mechanism changed easily once I figured out it needed to be on "start" to come out.
Also my switches "acc" stud was not very long and I had to extend it with a 3/8" long piece of 1/4" tubing I tapped for a 10-32 then added a lengthof 10/32 all thread......Good Luck
aussiebill
Posted 13 Years Ago
Posts: 1.8K, Visits: 11.4K
ronsplace (2/22/2012)
In 40 yrs of working on these cars have never needed any tools to remove ig bezel, are you aware you need to push switch forward from behind dash and this allows bezel to rotate easily. try it and see if that helps.Smile
 Down Under, Australia
Posted 13 Years Ago
Posts: 3.6K, Visits: 497.6K
Buy the tool - its cheap and makes everything easy.
