Going to rethink trans when putting the 292 in my 55
Posted By junkyardjeff 14 Years Ago
junkyardjeff
Posted 14 Years Ago
Last Active: 6 days ago
Posts: 813, Visits: 3.4K
My 55 presently has a 351 with a wrong cam so I bumped the gears from 2.79 to 3.00 and the motor is spinning more then I thought at 70 on the highway,those gears perked it up some around town but not as much as a I would like so I am thinking about going with 3.25 gears and a AOD with a Lentech valve body. I wanted to got with a FMX so I could use the original type starter but the AOD is starting to sound good so I can have a gear so it will run good around town and go comfortably down the highway.
Posted 14 Years Ago
Posts: 4.6K, Visits: 38.5K
I'm using a AOD behind my Y-Block with a 3.9 gear ratio. The engine turns about 2200 in overdrive at 60-65mph. I'm not sure if the 3.25 will be enough. I plan to put a set of 4:10's in it in the spring. Chuck
junkyardjeff
Posted 14 Years Ago
If 3.25s wont cut it will 3.55s work.
Posted 14 Years Ago
I don't know for sure if the 3:25's wouldn't work. Just my experience with the AOD. Chuck
Posted 14 Years Ago
Do you actually know how fast the engine is turning at 70?
Posted 14 Years Ago
About 2500 for my setup with the 3:80's. Chuck
The Master Cylinder
Posted 14 Years Ago
Posts: 974, Visits: 6.2K
In case anyone is interested the formula is;Smooooth rpm = mph x gear ratio x 336 / tire diameter Smooooth
Posted 14 Years Ago
MoonShadow (11/29/2011)
Oh, that was at Jeff.
For that formula, if you have overdrive, also multiply the overdrive ratio to find the overdrive rpm.
