Ford 292 Questions
Posted By ALL AMERICAN RACER 15 Years Ago
ALL AMERICAN RACER
Posted 15 Years Ago
Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)
Last Active: 14 Years Ago
Posts: 37, Visits: 101
does the motor mount come off without
pulling front dampener?
is there a fix for head around
spark plug holes?
has anybody milled a bigger flat
around spark plug holes?
2 spark plugs still in head
have to scrape off more grunge around
them and try it again
Ford 292 & Fordomatic
removed from '64 F100
Talkwrench
Posted 15 Years Ago
Posts: 898, Visits: 23.2K
For some reason on mine I could not get the the damper on after fitting front mount, had to pull it all apart and do some sort of juggling at the same time. Getting it off may have been the same. Just be more prepared when going to put it back on ..was a PITA !
Doug T
Posted 15 Years Ago
Posts: 563, Visits: 2.6K
As I remember you can not get the front motor mount off a '54 - 56 engine without pulling the harmonic damper. And you don't need to put it back on unless you want to. FoMoCo eliminated the front mount (it is actually called a steady rest) in '57. When I was a lad I put a '57 312 in my '54 and since my buddies and I hadn't any puller we couldn't get the front pully off the '54 engine so we installed the 312 without it. In 50,000 miles there was never any problem.
Doug T
aussiebill
Posted 15 Years Ago
Posts: 1.8K, Visits: 11.4K
ALL AMERICAN RACER (11/28/2011)
spark plug holes?
Damper off 1st then remove steady rest, you will see why. Use 21mm long socket, like a plug socket, it has thin walls and will get into head plug recess to enable better contact with plug. billSmile
 Down Under, Australia
