Wanted Y Block Hurst motor mount
Posted By niterunner71 14 Years Ago
niterunner71
Posted 14 Years Ago
First Time Poster
Posts: 2, Visits: 14
looking for hurst motor mount that was made to adapt y block to flathead type engine mounts. PM me if you have one this is for my y block powered 40 ford coupe project
SkylinerRon
Posted 14 Years Ago
Hitting on all eight cylinders (22 reputation)Hitting on all eight cylinders (22 reputation)Hitting on all eight cylinders (22 reputation)Hitting on all eight cylinders (22 reputation)Hitting on all eight cylinders (22 reputation)Hitting on all eight cylinders (22 reputation)Hitting on all eight cylinders (22 reputation)Hitting on all eight cylinders (22 reputation)Hitting on all eight cylinders (22 reputation)
Posts: 22, Visits: 53
FYI- The Hurst mounts require truck oil pan and pickup, frt cover and some other stuff.
I put a Y in a 51 vic back in the 60's w/Hurst set up and the crossmember is a problem w/them also. If I were doing this swap I think I would rather get the FE to Truck aftermarket crossmember. The FE motor mount pads are the same as Y's.
Goodluck,
Ron.
