Wanted Y Block Hurst motor mount
http://forums.y-blocksforever.com/Topic66059.aspx
By niterunner71 - 14 Years Ago
looking for hurst motor mount that was made to adapt y block to flathead type engine mounts. PM me if you have one this is for my y block powered 40 ford coupe project
By SkylinerRon - 14 Years Ago
FYI- The Hurst mounts require truck oil pan and pickup, frt cover and some other stuff.
I put a Y in a 51 vic back in the 60's w/Hurst set up and the crossmember is a problem w/them also. If I were doing this swap I think I would rather get the FE to Truck aftermarket crossmember. The FE motor mount pads are the same as Y's.
Goodluck,
Ron.
