randyh
Visits: 42.1K
I have tried evaporust on some small parts it did a really good job, I was impressed. It was available at the local tractor supply in 1 gallon jug for about $20.
jrw429
Visits: 4.3K
Molasses is used due to the organic chelating agents in it. Here's a chelating product specifically for rust removal. I've not tried any of this, just doing research right now. http://www.orisonmarketing.com/corrosion/evaporust/evapo-rust.html
Jim - Erie Colorado, 1957 Country Sedan
aussiebill
Posts: 1.8K,
Visits: 11.4K
Grizzly (10/14/2011)
Lon, Yes I've used molasses. 1:4 with water really great for cleaning iron or steel parts. I've seen all sorts of people who use it. Even one guy who had a 200 ltr drum set up in his engine recon business. Like you say a little slow but safe. Throw your part in and check it in a week or a few days never seems to take more than the corrosion. But like I said safe, if you forget about it or don't get time you don't come back to nothing. I didn't like the reaction when there was more than one metal (aluminium & steel) in the drum. cheers Warren Yes, i ,ve used it for years, anything rusty will come up like new but must be thoriughly cleaned with hot soapy water or chemical based cleaner to halt the process, my engine reconditioner soaks all his blocks before machining.
Grizzly
Visits: 1.9K
Grizzly (Aussie Mainline)
pintoplumber
Posts: 1.0K,
Visits: 164.0K
Lon, I can believe molasses would work. We get to work at a couple of feed mills that use molasses in the feed. The pipes are nice and clean inside and after a number of years it eats through the threads.
Dennis in Lititz PA
bird55
Posts: 1.1K,
Visits: 58.8K
You CAN still buy MEK. I hadn't realized! BUT still the stuff is questionable to use I think. The smell will knock you over quick. Use it outdoors. I looked it up http://en.wikipedia.org/wiki/Butanone and it doesn't seem as bad as I thought? Last time I used it it was recommended to rinse out a gas tank before applying sealant. I'm starting to get headache just thinking about.  OH yea, forgot to add HIGHLY FLAMMABLE and Explosive.
LON
Visits: 3.7K
Chuck , I know its low tech,slow & smelly ,but have you ever used molasses ??? I think its about 5lb of molasses to 5 gallons of water ( I stand to be corrected on this ) .It is a lot safer than acid .The only downfall is the time .Some parts can take 2 or 3 weeks to clean . The smell is the worst part .Add more molasses to make it stronger . See if you can get hold of a 55 Gallon plastic drum & cut it to suit your needs .You will not believe how clean an old block will look ??? Has anyone else used molasses to clean metal parts . Lon
yblocksdownunder
The Master Cylinder
Visits: 6.2K
bird55
Posts: 1.1K,
Visits: 58.8K
Chuck, i think this has been discusse at length over at the HAMB, so you might check there. Also just the addition of a small electric fountain styl pumps helps some. I miss using laquer thinner and MEK and all that other good stuff. GEE, i wonder why my hands shake now at my age?
Visits: 38.2K
I stand warned on the Caustic Soda. Won't try that. I've looked into home made ultrasonic cleaners but as soon as they start talking about sound cards and specific frequencies I'm done! I have seen some larger and very large industrial units but they start at over $3000. Way out of my price range for a home use parts cleaner. There is a demo of one at the Jay Leno garage site. Big enough for heads and maybe a block. It looks like an answer to the poor quality cleaners we have to use now. I did find that Simple Green is said to work better with heat and am looking into a tank heater. One site suggested using a couple magnetic block heaters. I would prefer something that heated a bit quicker so I don't have to leave it on all the time. I'm also thinking about adding an air line to the tank to move the solution. Thats supposed to help with cleaning submerged parts. Chuck
