Parts cleaning
http://forums.y-blocksforever.com/Topic64394.aspx
By MoonShadow - 14 Years Ago
Has anyone messed around with making a ultrasonic unit to fit on a parts washer? Seem like the way to go for clean parts but the units large enough for heads etc. are real pricy. I would think a unit could be made to attach to the side or bottom of an existing tank. Would caustic soda, added to the mix, make the solution more acidic.
Also, I'm using Simple Green in a 20gal tank now. Lousy compared to the EPA banned cleaners. I'm thinking of adding a heat unit and air to the tank. Any thoughts? Sure wish I still had a 50gal drum of ZEP hidden away. But that stuff is real bad for the environment.
Thanks, Chuck
MoonShadow (10/8/2011)
Thanks, Chuck
Chuck, Caustic Soda (Sodium Hydroxide, NaOH) is a strong base or aklaline material having a pH above 7 which is the opposite of an acid and would neutralize an acid and possibly causing a violent reaction, depending on the strengths. NOT a good idea to mix the two.Sick
By stuey - 14 Years Ago
Master cylinder is right, its an alkaline and, if i remember correctly it will eat ally parts.
the only ultrasonic cleaners i've seen are very small and used by jewellers and dental techs. they use paezio electric crystals which brings something else to mind,somebody built a carb using such a device back in the 60s don't think it caught on. bigger ultrasonic cleaners use transformers and the vibrations caused in the laminations. feel free to experimentBigGrin
stuey
I stand warned on the Caustic Soda. Won't try that. I've looked into home made ultrasonic cleaners but as soon as they start talking about sound cards and specific frequencies I'm done! I have seen some larger and very large industrial units but they start at over $3000. Way out of my price range for a home use parts cleaner. There is a demo of one at the Jay Leno garage site. Big enough for heads and maybe a block. It looks like an answer to the poor quality cleaners we have to use now.
I did find that Simple Green is said to work better with heat and am looking into a tank heater. One site suggested using a couple magnetic block heaters. I would prefer something that heated a bit quicker so I don't have to leave it on all the time. I'm also thinking about adding an air line to the tank to move the solution. Thats supposed to help with cleaning submerged parts. Chuck
By bird55 - 14 Years Ago
Chuck, i think this has been discusse at length over at the HAMB, so you might check there. Also just the addition of a small electric fountain styl pumps helps some.
I miss using laquer thinner and MEK and all that other good stuff. GEE, i wonder why my hands shake now at my age? w00t
Alan, I'm surprised you can even by MEK anymore. Seen it at Home Depot the other day while looking for something else. w00tw00t Nasty Stuff...
By LON - 14 Years Ago
Chuck ,
I know its low tech,slow & smelly ,but have you ever used molasses ??? I think its about 5lb of molasses to 5 gallons of water ( I stand to be corrected on this ) .It is a lot safer than acid .The only downfall is the time .Some parts can take 2 or 3 weeks to clean . The smell is the worst part .Add more molasses  to make it stronger .
See if you can get hold of a 55 Gallon plastic drum & cut it to suit your needs .You will not believe how clean an old block will look ??? Has anyone else used molasses to clean metal parts .
Lon
You CAN still buy MEK. I hadn't realized! BUT still the stuff is questionable to use I think. The smell will knock you over quick. Use it outdoors.
I looked it up http://en.wikipedia.org/wiki/Butanone and it doesn't seem as bad as I thought? Last time I used it it was recommended to rinse out a gas tank before applying sealant.
I'm starting to get headache just thinking about. w00t
OH yea, forgot to add HIGHLY FLAMMABLE and Explosive. Hehe
By pintoplumber - 14 Years Ago
Lon, I can believe molasses would work. We get to work at a couple of feed mills that use molasses in the feed. The pipes are nice and clean inside and after a number of years it eats through the threads.
By Grizzly - 14 Years Ago
Lon,
Yes I've used molasses. 1:4 with water really great for cleaning iron or steel parts. I've seen all sorts of people who use it. Even one guy who had a 200 ltr drum set up in his engine recon business.
Like you say a little slow but safe. Throw your part in and check it in a week or a few days never seems to take more than the corrosion. But like I said safe, if you forget about it or don't get time you don't come back to nothing.
I didn't like the reaction when there was more than one metal (aluminium & steel) in the drum.
cheers
Warren
By aussiebill - 14 Years Ago
Grizzly (10/14/2011)
Lon,
cheers
Warren
Yes, i ,ve used it for years, anything rusty will come up like new but must be thoriughly cleaned with hot soapy water or chemical based cleaner to halt the process, my engine reconditioner soaks all his blocks before machining.BigGrin
By jrw429 - 14 Years Ago
Molasses is used due to the organic chelating agents in it. Here's a chelating product specifically for rust removal. I've not tried any of this, just doing research right now.
http://www.orisonmarketing.com/corrosion/evaporust/evapo-rust.html
By randyh - 14 Years Ago
I have tried evaporust on some small parts it did a really good job, I was impressed.  It was available at the local tractor supply in 1 gallon jug for about $20.
