How hard should it be to stop the car with manual drum brakes?
Posted By Big6ft6 15 Years Ago
Pete 55Tbird
Posted 15 Years Ago
Posts: 721, Visits: 93.2K
Nate
Your brakes take too much effort. SOMETHING IS WRONG WITH THEM. PERIOD.
When these cars were new they were driven by little old ladies who weighed less tha 100 lbs with out a problem.
Something to consider is that the brake shoes have overheated and become "GLAZED" and the co efficient of friction has decreased to the point where you have to exert a great deal of force to stop your car. Do a Google search. Pete
Posted 15 Years Ago
Posts: 3.7K, Visits: 323.8K
Nate:
I wonder if the Bronco has a longer pedal, or the distance from the pedal pivot to the master cylinder actuator bolt is shorter than the '56.  Either of these conditions would cause an increase in pedal pressure on your car.  Does the actuator rod enter the master cylinder at an angle, or does it go straight in?  If at an angle, that would indicate the geometry is wrong.
Tom Compton
Posted 15 Years Ago
Supercharged (311 reputation)Supercharged (311 reputation)Supercharged (311 reputation)Supercharged (311 reputation)Supercharged (311 reputation)Supercharged (311 reputation)Supercharged (311 reputation)Supercharged (311 reputation)Supercharged (311 reputation)
Posts: 287, Visits: 4.0K
I agree with Pete and Hossier that the Bronco master is probably not right for the application.  I had a 56 in 63-66 and this one since 2001 with factory manual brakes.  I am (or was) 6'5" and did not have to raise the heel on either of the originals.
No excessive work required.  Changed this year to ScareBird's disc setup and power booster as one too many brake fades and wanted redundancy of dual master.  In doing so, considered not putting a power booster on and learned of the importance of the diameter on the manual master.
Good luck.
You gotta have the right tools and know how to use 'em.
TC - Austin, Texas
rick55
Posted 15 Years Ago
Supercharged (658 reputation)Supercharged (658 reputation)Supercharged (658 reputation)Supercharged (658 reputation)Supercharged (658 reputation)Supercharged (658 reputation)Supercharged (658 reputation)Supercharged (658 reputation)Supercharged (658 reputation)
Posts: 550, Visits: 4.4K
Just to throw another thing to check into the mix - do you have the shoes fitted correctly? From my memory, the shorter shoe should be to the front - leading shoe. If installed incorrectly they will work but will need extra pressure.
By your post you indicate you are 6'6" so I would think that leg strength is not the issue.
A good operating drum brake system will work just as well as a disc brake system, but will fade quicker when used excessively.
The brakes fitted to 55/6 Fords are more than adequate even when compared to late model cars.
Regards
Rick - West Australia
Posted 15 Years Ago
My 57 car also requires heavy pressure to get anything like reasonable stopping. However, here's some info I just read in Hemmings Classic Car, October 2011 edition, that may bear on this problem. I had not heard this information in any form before. The article is entitled "Get A Grip". Briefly, it states that when Asbestos was legislated out of brake lining materials, a substitute had to be found. The replacement material developed was by the Ferodo Co. & called 3410F. Unfortunately, for older cars like ours, the new material does not have the same feel & performance as the old brake lining materials, when used with vintage cast brake drums. Later brake drums & rotors when combined with the new lining materials, were a different alloy of cast iron, containing amongst other materials, graphite... Anyone really effected by this hard brake situation might want to obtain a copy, it's very interesting reading. Unfortunately, it does not spell out any solution to the problems discussed here....
292fan
Posted 15 Years Ago
Posts: 19, Visits: 189
Hi, I have a '60 Galaxie with the drum/drum brakes. For a big car it doesn't take the force that I would expect. I can stop the car with my heel on the floor, but I prefer to lift it just in case. As to coming off a highway, with to combo of the 2 speed trans braking and the brakes like they are, there has never been an issue. Pedal travel is 1 inch and all cylinders are OEM. My '64 F100 is the same effort even with the manual trans and OEM cylinders. One thing that I found to play an important role is the shoe adjusters. Since mine are not automatic, adjustment is critical. Especially a few miles after shoe replacement.
292fan
Big6ft6
Posted 15 Years Ago
Supercharged (272 reputation)Supercharged (272 reputation)Supercharged (272 reputation)Supercharged (272 reputation)Supercharged (272 reputation)Supercharged (272 reputation)Supercharged (272 reputation)Supercharged (272 reputation)Supercharged (272 reputation)
Posts: 241, Visits: 347
Man, I was just coming around the other side of this issue and believing that my brakes are fine.  I drove to work today and am starting to get used to them.  I really do believe that one problem is that my legs are so long I cannot push straight on the pedal, my leg is very bent and kind of at an angle (seats don't go far enough back for me!).
The bronco master cylinder was recommended in other posts on this site.  It is a 1" diameter bore and is a direct fit in the original firewall opening, so the push rod angle is identical to OEM.  Since the master cylinder bore diameter is the same as OEM I can't think of anything else about the master cylinder that would make it not work?  A 1" diameter piston moving the same distance should move the same amount of fluid at the same pressure as the OEM.  The only thing different is that it comes from two different ports instead of one, but since I don't have a proportioning valve there shouldn't have been any bias introduced.
My brake pads are on in the correct order (someone pointed out I had them on backward in some of my earlier brake posts when I was redoing the brake systemWink)
It may have something to do with the pad material like Paul mentions, the older material may have made it easier for thsoe 100 lb little old ladies form Pasadena!  Someone pointed out there is a comany that makes replacement pads out of a different softer material that is supposed to help these old cars stop like the used to...but the downside is the material gets used up faster.
I could also just be that I'm a little whimpy after driving modern cars for the last 17 years.Smile
I've found one trick that helps is to put my heel on the pedal, not my toes, I can get some good pressure then without quite as extreme knee angle (hip to heel length is a little shorter than hip to toe).
I'll keep thinking and considering all of your thoughts. Thanks for all the ideas.  Maybe I'll get a chance to drive someone else's car of this vintage so I can compare, or they could drive mine.
Nate - Madison, Wisconsin
56 Ford Customline Sedan
Posted 15 Years Ago
Posts: 4.6K, Visits: 39.3K
Hey, its on the road and driving. Thats great! Does your seat go back in the tracks? Makes sure it goes all the way back. If it won't go back far enough its not unheard of to relocate the seat tracks towards the rear just remember to leave a little leg room in the back. Chuck
petew
Posted 15 Years Ago
Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)
Last Active: 2 Weeks Ago
Posts: 180, Visits: 5.0K
I drove myself crazy with this on my 56 Merc and the problem wound up being an improper pedal ratio. If you google "brake pedal ratio calculator" you will see that a 6 to 1 ratio is needed for manual brakes . Once I changed the brake rod location on my brake pedal it was a different car . A brake pedal is just a lever , the longer the lever the less effort required .
Pete
Grizzly
Posted 15 Years Ago
Posts: 281, Visits: 1.9K
Nate,
I'm wondering if you have increased the amount of pressure require as you now have two pistons ie, one for each circuit, that you have doubled the pressure required to stop because you have effectively halved your hydraulic ratio.
I'd do an internet search and try to find out how to calculate hydraulic ratios. I know that the lever ratio's used for your ford are high for power assisted but are low for racing setups that do not use boosters. I checked this out before upgrading my brakes.
My ex wife used to drive my 56 with non assisted drum brakes and she could barley reach the pedals. she used to wriggle forward to floor the accelerator. She only complained about the steering. (and everything else in life) I found that the car braked well with drums even better that some 70's era cars with power disks. the pedal was never hard although it sometimes needed some muscle to stop quickly.
You may have made a mistake. Personally I would have gone with one of old irsh daves master booster setup there are plenty of posts on these including a current one in technical. For $170 do yourself a favor and upgrade your brakes.
cheers
Warren
http://forums.y-blocksforever.com/Uploads/Images/41f30774-424d-428d-9c7a-e351.jpg Grizzly (Aussie Mainline)
