How hard should it be to stop the car with manual drum brakes?
http://forums.y-blocksforever.com/Topic64062.aspx
By Big6ft6 - 15 Years Ago
So I've been driving the customline this week for errands and to work even BigGrin  it is awesome.   One thing that is quite un-awesome is the amount of pedal force I have to exert to stop the car.  Anyone who has followed my build knows I have a completely new brake system from master cylinder (68 bronco) to the drums.  I have a very firm pedal and what seems to be appropriate pedal travel, but the responsiveness of the brakes leaves much to be desired.
I have to pick my heel off the floor and push with full leg muscles to get a braking response similar to normal braking on my modern cars.  Since I'm a tall guy my leg is bent at an akward angle and driving around town I'm starting to get knee pain.  I'm a very conservative driver and slow down early.
If I really stand on it, I can get the wheels to lock up (I've tried on some country roads) so the brakes are working, but they are just hard.  Sometimes if stopped on even a moderate incline with my foot on the brake the car starts to roll backward and I quickly have to apply more pressure, If I have to stay stopped on the incline for any length of time, the amount of pressure I need to keep on the pedal gets uncomfortable (sorry if I'm sounding a little wussy!)
Since I'm not familiar with what is "normal" for manual drum brakes I'm looking for some feedback/descriptions on what it should be like.  For example, can you typically stop coming down a normal freeway off ramp without picking your heel off the floor?  How does it compare to a modern car with power disc/drum?
By stlroken - 15 Years Ago
Nate, I have a 56 with drum brakes and no power and have usual pedal travel but sometimes, like comeing down an on ram...I really have to stand on them. They do stop and stop even without pulling but it does take some pressure. I've had the car for 14 years and has always been the same. This probably won't help you much but maybe a little.
Jim
Washington, Ia
By YellowWing - 15 Years Ago
My car was originally a power brake car.... however when the front discs were installed they disconnected the power booster. The first time I drove it I found the brakes were good it just took a lot of pedal pressure. I installed a new booster a week later. Mike
By Pete 55Tbird - 15 Years Ago
You say it takes too much force on the brake pedal to stop your car. Granted a 50s Ford with manual drum brakes will require more effort to stop than any new car but what you are describing it NOT NORMAL and is dangerous.
When you replaced the master cylinder with the 1968 Bronco do you know what the diameter of the piston in that cylinder is? If the 56 Ford master cylinder piston was 3/4 inch and you replaced it with a Bronco master cylinder piston that is 1 inch then the force required to stop has been INCREASED over 75%. Please do a GOOGLE SEARCH to verify this.
Good luck and tell us whatr you find out. Pete
By Talkwrench - 15 Years Ago
I found it took alot with mine, always had to prepare for stopping etc, and the brakes on mine had be done with all new parts.. since changing to a dual circuit power boosted sytem, its the only way to go. A must!
Pete, I was wondering about that too.  My understanding is that the original MC was 1" so I looked for other that are also 1" and other posts on this site recommended the 68 bronco as a bolt in.  So unless someone corrects me, the master cylinder diameter hasn't changed.
It sounds like maybe the extra pressure isn't unusual.  It maybe a bit tougher with my ogre legs, I can't push the pedal straight on...I'm coming from the side.
I might have to look into a booster....
By fairlane bob - 15 Years Ago
I have a 1956 Fairlane 2/doorpost and I just put 2200 miles on it driving from N Jersey to Missouri and back with a LOTof extra stuff in trunk and back seat in Sept of this year as I did in a couple of previous years ,But my daily driver is a 68 Falcon wagon with manuel brakes so the amount of petal pressure does fill simular.
But if I git in my F100 with the power disk brakes takes a couple miles to git used to them.I think the 56 with stock brakes is reasonable unless you grew up only with cars with power brakes or disk brakes. There is a web site for a place out west www. praisedynobrake.com that clames to make special shoes for older drumn brake cars to help them stop better Like old Muscle cars,they have a phone # to contact about what you may need! I never really felt the need it slowed fine,even on the hills in western Pa.i
Nate
Your cars brakes are not "normal" and there is something wrong with them if extreme force is required to make the car stop.
Ford sold a million cars without power brakes just like yours and they all stopped with no issues and no drama.
Along with the diameter of the piston in the Bronco master cylinder are the wheel cylinders you are using also the original size that came with the car? If you drive on a gravel road and lock the brakes do the front brakes apply first and then the rear?
Did you car every have a power brake booster on it?
Keep going to the gym until you fix the problem Pete
By glrbird - 15 Years Ago
Nate
Fairlane Bob is on to something, When you turned the drums were you able to "Arc" the shoes to the drums? It is an old processes that mates the shoes to the drum exactly. When we did this to a front engine dragster with rear brakes only, it made a drastic difference in holding and stopping. We also used brake shoes with soft linings. Disk brakes would not hold the car on the starting line when you stalled it. You might have trouble finding a shop that can still do this type of work. Look for older business that have there own brake machines. Good Luck
Gary - no I did not arc the shoes, I asked the shop that did my drums about that and they didn't offer the service.  But I placed the new shoes inside my drum after they were turned and they fit very nicely, at least I couldn't see any gaps in the arc match...but maybe even a mismatch that I can't see can cause a problem?
Pete - The wheel cylinders are all OEM spec parts.  I know you're right that braking effort shouldn't be "extreme", but maybe what feels extreme to me isn't really extreme since I've grown up driving power disc/drum cars my whole life.  It's just not what I'm used to, but maybe I'm just a young "softie" Wink when it comes to pushin' the pedal.   I will do the gravel road test when i get a chance, i was trying to tell on a wet country road the other day but I couldn't tell what was locking up first.
This is why I'm looking for some descriptions I can use to calibrate my experience to other's, for example the effort I need requires my heel lift up off the floorboard when I'm coming down an off ramp.  In my  modern car, my heel is ALWAYS on the ground and I can create enough effort to brake by just pressing with my foot leaving my heel planted.  If someone could confirm whether they leave their heel planted while braking or whether sometimes they need to lift their heel off the floor too, that would help make our descriptions more objective rather than subjective.
I'm guessing maybe Gary is on to something, maybe my car is a little harder becuase the shoes aren't perfectly formed,  but most of what I'm feeling is likely just becuase I'm young and have lived a sheltered life with power brakes.  I drove to work again this morning, and the effort is right on the border of being tollerable, I can stop o.k. I don't feel like I'm dangerous on the road, but if I drove this car much I'd definitly get some new bulging leg muscles!
If someone is in Madison any time this fall, let me know and you can drive my car around and let me know what you think.
By PWH42 - 15 Years Ago
Nate...........I'm 6'1'' and 200 pounds and I walk 4-5 miles a day,so my legs are in pretty good shape.Driving my manual drum brake cars requires me to use a lot of leg.I think that your concern is simply because you've always had power brakes and need to get accustomed to to non-power.
By bergmanj - 15 Years Ago
You will need "full-leg" use for those manual brakes - no "heel on the floor"!  I've driven many of those '54 / '55 / '56 ford cars for many years, and a "full-leg" is necessary.
Regards,   JLB
By old cars - 15 Years Ago
You do have to lift your leg on non power and push there not like power brakes but they do stop the car alrightSmile
I drive a 55 vicky, a 58 F100 and many other non powered brake cars, However, I have a 1969 F100 and the brakes on that take much more effort to push than any of my others and you say you used a 68 master, it may have something to do with the years. I asked someone who drove those year trucks all the time because I thought mine were were bad and he said thats how they were in those years.
Just think positive, you will always have muscular legs.
By MoonShadow - 15 Years Ago
Its difficult to say without feeling the actual pressure needed. If you are used to modern cars then the brake will surely feel harder. Having owned Fords from the 50's on I don't notice it so much. I just know I have to push harder on the early Fords to stop.
One question though, how far does the brake pedal travel before you feel pressure? It should have at least 1" or more free travel to work correctly.
Chuck
By Grizzly - 15 Years Ago
I Used to call my non-power brakes in my 56 as adrenaline assisted Wink
Cheers
Warren
By Park Olson - 15 Years Ago
Did you replace the hoses? If not, they could be swelled inside to the point that they are not passing fluid properly.
By Ivan M. Thoen - 15 Years Ago
Maybe you have the optional antistop brakes.
When I read Grizzly's post I knew my breaks were working just fine BigGrin   I couldn't said it better myself.
Chuck, I'd guess that my pedal travels 1-2" before it gets real firm.  The pedal feel is nice as far as travel and firmness.
Park, yep, replaced everything bewteen the pedal and the drum.
Are there any other Y-Blocker's around that could do a feel test for you? That would answer the question once and for all. As i recall you went through quite a process to get the brakes set up and bled correctly. Are the shoes on right so that the brakes "self activate" when you push the pedal? If all else is correct then you will need to allow time for your leg muscles to build up. Being used to modern brakes the feeling is quite different! Chuck
Nate
Your brakes take too much effort. SOMETHING IS WRONG WITH THEM. PERIOD.
When these cars were new they were driven by little old ladies who weighed less tha 100 lbs with out a problem.
Something to consider is that the brake shoes have overheated and become "GLAZED" and the co efficient of friction has decreased to the point where you have to exert a great deal of force to stop your car. Do a Google search. Pete
Nate:
I wonder if the Bronco has a longer pedal, or the distance from the pedal pivot to the master cylinder actuator bolt is shorter than the '56.  Either of these conditions would cause an increase in pedal pressure on your car.  Does the actuator rod enter the master cylinder at an angle, or does it go straight in?  If at an angle, that would indicate the geometry is wrong.
By Tom Compton - 15 Years Ago
I agree with Pete and Hossier that the Bronco master is probably not right for the application.  I had a 56 in 63-66 and this one since 2001 with factory manual brakes.  I am (or was) 6'5" and did not have to raise the heel on either of the originals.
No excessive work required.  Changed this year to ScareBird's disc setup and power booster as one too many brake fades and wanted redundancy of dual master.  In doing so, considered not putting a power booster on and learned of the importance of the diameter on the manual master.
Good luck.
By rick55 - 15 Years Ago
Just to throw another thing to check into the mix - do you have the shoes fitted correctly? From my memory, the shorter shoe should be to the front - leading shoe. If installed incorrectly they will work but will need extra pressure.
By your post you indicate you are 6'6" so I would think that leg strength is not the issue.
A good operating drum brake system will work just as well as a disc brake system, but will fade quicker when used excessively.
The brakes fitted to 55/6 Fords are more than adequate even when compared to late model cars.
Regards
By PF Arcand - 15 Years Ago
My 57 car also requires heavy pressure to get anything like reasonable stopping. However, here's some info I just read in Hemmings Classic Car, October 2011 edition, that may bear on this problem. I had not heard this information in any form before. The article is entitled "Get A Grip". Briefly, it states that when Asbestos was legislated out of brake lining materials, a substitute had to be found. The replacement material developed was by the Ferodo Co. & called 3410F. Unfortunately, for older cars like ours, the new material does not have the same feel & performance as the old brake lining materials, when used with vintage cast brake drums. Later brake drums & rotors when combined with the new lining materials, were a different alloy of cast iron, containing amongst other materials, graphite... Anyone really effected by this hard brake situation might want to obtain a copy, it's very interesting reading. Unfortunately, it does not spell out any solution to the problems discussed here....
By 292fan - 15 Years Ago
Hi, I have a '60 Galaxie with the drum/drum brakes. For a big car it doesn't take the force that I would expect. I can stop the car with my heel on the floor, but I prefer to lift it just in case. As to coming off a highway, with to combo of the 2 speed trans braking and the brakes like they are, there has never been an issue. Pedal travel is 1 inch and all cylinders are OEM. My '64 F100 is the same effort even with the manual trans and OEM cylinders. One thing that I found to play an important role is the shoe adjusters. Since mine are not automatic, adjustment is critical. Especially a few miles after shoe replacement.
292fan
Man, I was just coming around the other side of this issue and believing that my brakes are fine.  I drove to work today and am starting to get used to them.  I really do believe that one problem is that my legs are so long I cannot push straight on the pedal, my leg is very bent and kind of at an angle (seats don't go far enough back for me!).
The bronco master cylinder was recommended in other posts on this site.  It is a 1" diameter bore and is a direct fit in the original firewall opening, so the push rod angle is identical to OEM.  Since the master cylinder bore diameter is the same as OEM I can't think of anything else about the master cylinder that would make it not work?  A 1" diameter piston moving the same distance should move the same amount of fluid at the same pressure as the OEM.  The only thing different is that it comes from two different ports instead of one, but since I don't have a proportioning valve there shouldn't have been any bias introduced.
My brake pads are on in the correct order (someone pointed out I had them on backward in some of my earlier brake posts when I was redoing the brake systemWink)
It may have something to do with the pad material like Paul mentions, the older material may have made it easier for thsoe 100 lb little old ladies form Pasadena!  Someone pointed out there is a comany that makes replacement pads out of a different softer material that is supposed to help these old cars stop like the used to...but the downside is the material gets used up faster.
I could also just be that I'm a little whimpy after driving modern cars for the last 17 years.Smile
I've found one trick that helps is to put my heel on the pedal, not my toes, I can get some good pressure then without quite as extreme knee angle (hip to heel length is a little shorter than hip to toe).
I'll keep thinking and considering all of your thoughts. Thanks for all the ideas.  Maybe I'll get a chance to drive someone else's car of this vintage so I can compare, or they could drive mine.
Hey, its on the road and driving. Thats great! Does your seat go back in the tracks? Makes sure it goes all the way back. If it won't go back far enough its not unheard of to relocate the seat tracks towards the rear just remember to leave a little leg room in the back. Chuck
By petew - 15 Years Ago
I drove myself crazy with this on my 56 Merc and the problem wound up being an improper pedal ratio. If you google "brake pedal ratio calculator" you will see that a 6 to 1 ratio is needed for manual brakes . Once I changed the brake rod location on my brake pedal it was a different car . A brake pedal is just a lever , the longer the lever the less effort required .
Pete
Nate,
I'm wondering if you have increased the amount of pressure require as you now have two pistons ie, one for each circuit, that you have doubled the pressure required to stop because you have effectively halved your hydraulic ratio.
I'd do an internet search and try to find out how to calculate hydraulic ratios. I know that the lever ratio's used for your ford are high for power assisted but are low for racing setups that do not use boosters. I checked this out before upgrading my brakes.
My ex wife used to drive my 56 with non assisted drum brakes and she could barley reach the pedals. she used to wriggle forward to floor the accelerator. She only complained about the steering. (and everything else in life) I found that the car braked well with drums even better that some 70's era cars with power disks. the pedal was never hard although it sometimes needed some muscle to stop quickly.
You may have made a mistake. Personally I would have gone with one of old irsh daves master booster setup there are plenty of posts on these including a current one in technical. For $170 do yourself a favor and upgrade your brakes.
cheers
Warren
By Jeff - 15 Years Ago
One item that may have been overlooked is the brake lining material. With harder brake material the linings last but braking performance is sacrificed.
I live in the Vancouver WA/Portland OR area and have access to a great business called Ott's Friction Supply. They turn drums, reline shoes and arc the shoes to the drums. They have options as to the friction material being used.
My two bits.
Jeff
By aussiebill - 15 Years Ago
Grizzly (10/15/2011)
Nate,
cheers
Warren
Nate, here are some random thoughts i have re your brakes and may not apply to your layout. On some customlines there is a little short rubber brake hose between orig m/cyl and metal brake line, if there, it could be closing on application, restricting flow, but unlikely if you have replumbed to dual circuit m/cyl. OR if using old orig shoes, they could be hardened up now and reccommend going to new relined shoes with current material as mentioned/ is there a pic of the m/cyl and plumbing as it may help. it seems strange 6' or 5' that you have to apply so much pressure for little result. OR Is the rear brake hose clear, they often get hard or soft and can restrict flow to rears and haveing front do all the work. I recently had lincoln brakes pull to left and from expeirence thought the RH side is not working and WAS as i thought blocked RHF brake hose, changed it and 100% perfect.
Keep up your progress.
yyyy
By ejstith - 15 Years Ago
I have manual drum brakes & the original master cylinder & it stops fine. I mean it's not power brakes but maybe I just revert to "back in the day" when they were all like that...
