factory dual quad manifold
Posted By 55ebird 15 Years Ago
carl
Posted 15 Years Ago
Posts: 1.2K, Visits: 20.7K
I have a ECG-9424- D  manifold that just has one plug on the bottom,also the number i found was on 5-6 runner and it is 1-63 G9, so is that a date code ?  Carl
Posted 15 Years Ago
Posts: 7.6K, Visits: 206.1K
Carl.  Both the number and location don’t fit what’s found on the run of the mill ’57 dual quad intakes.  Got a picture?  Due to both the numbering and the ‘one plug on the bottom’, your intake manifold sounds different than the majority which could make it potentially an early production unit.
carl
Posted 15 Years Ago
Ted   I will try to post a couple pictures of the intake this week  Carl
Dennis K.
Posted 15 Years Ago
Supercharged (158 reputation)Supercharged (158 reputation)Supercharged (158 reputation)Supercharged (158 reputation)Supercharged (158 reputation)Supercharged (158 reputation)Supercharged (158 reputation)Supercharged (158 reputation)Supercharged (158 reputation)
Posts: 143, Visits: 451
My 8V intake has a cast in 1-9 date code on top near the thermostat port, two diagonal threaded core plugs, and a stamped "S" below the cast in "ECG9424-D"  part number on the bottom side.
Another comment is the ratio of 8V intake manifolds one sees, compared to the correct 8V carbs and/or linkage sets.
Regards,
Dennis
tbirddragracer
Posted 15 Years Ago
Supercharged (132 reputation)Supercharged (132 reputation)Supercharged (132 reputation)Supercharged (132 reputation)Supercharged (132 reputation)Supercharged (132 reputation)Supercharged (132 reputation)Supercharged (132 reputation)Supercharged (132 reputation)
Last Active: 4 Months Ago
Posts: 56, Visits: 95.8K
Ted,
Dual four manifolds
12-14
3-29
2-28
3-13
Ernie Phillips
Posted 15 Years Ago
Thanks to all for the updates.
Here’s the revised list thus far for 22 intake manifolds.  Carl’s intake falls outside of the list for now.
10-15-56 (JH)
12-5 (JH), 12-13 (JH), 12-14 (Ted), 12-14 (EP)
1-9 (DK), 1-18 (JH), 1-22 (Ted), 1-22 (Genuinerod)
2-28 (JH), 2-28 (EP)
3-6 (JH), 3-7 (JH), 3-8 (JH), 3-13 (JH), 3-13 (EP), 3-29 (Ted), 3-29 (EP)
4-3 (JH)
6-5-57 (Ted), 6-6-57 (JH), 6-10 (JH)
Oldmics
Posted 15 Years Ago
Posts: 710, Visits: 78.1K
Ted (10/4/2011)
Spotted today at Hershey-12-28, 2-4, 6-3  Added to the list
Here’s the revised list thus far for 25 intake manifolds.  Carl’s intake falls outside of the list for now.
10-15-56 (JH)
12-5 (JH), 12-13 (JH), 12-14 (Ted), 12-14 (EP), 12-28 (JH)
2-4 (JH), 2-28 (JH), 2-28 (EP)
4-3 (JH)
6-3 (JH), 6-5-57 (Ted), 6-6-57 (JH), 6-10 (JH)
Spotted today at Hershey-12-28, 2-4, 6-3  Added to the list      Oldmics
YBLOCKMERC
Posted 15 Years Ago
Posts: 194, Visits: 20.6K
I was at the Monroe Swap Meet in Washington today and found two 8V manifolds. One had the two threaded plugs in the bottom and 12-6 on top of the thermostat cavity. It had two Carter WCFBs on it but no linkage. No idea if they have ever been run on the manifold.
The other was an ECZ 9424-C with no large threaded plugs on the bottom although there was one small (~.25) threaded cap on the bottom.
Marc
'54 Merc ragtop
Pt Townsend, WA
      http://forums.y-blocksforever.com/uploads/images/e83cf74f-a3dc-4e1a-a928-8075.jpg
ecode ragtop
Posted 15 Years Ago
Supercharged (443 reputation)Supercharged (443 reputation)Supercharged (443 reputation)Supercharged (443 reputation)Supercharged (443 reputation)Supercharged (443 reputation)Supercharged (443 reputation)Supercharged (443 reputation)Supercharged (443 reputation)
Posts: 285, Visits: 3.4K
My 2x4 intake has a casting date of 12-17   Tom
  JUST A MIDNIGHT CRUISE DOWN THUNDER ROAD!!! TOM DRUMMOND MIDWEST DIRECTOR 57 FORD INTERNATIONAL
Flatrod
Posted 15 Years Ago
Hitting on all eight cylinders (17 reputation)Hitting on all eight cylinders (17 reputation)Hitting on all eight cylinders (17 reputation)Hitting on all eight cylinders (17 reputation)Hitting on all eight cylinders (17 reputation)Hitting on all eight cylinders (17 reputation)Hitting on all eight cylinders (17 reputation)Hitting on all eight cylinders (17 reputation)Hitting on all eight cylinders (17 reputation)
Posts: 5, Visits: 1.6K
My ECG-D intake is dated 6-6-57.
