Last Active: 10 hours ago
Visits: 39.3K
It was a new, balanced, 40 over 272 with the blower cam etc.. Lost oil pressure at Columbus after about 500 miles of travel. Number 2 main bearing was badly worn and the two adjacent rods had a lot of heat damage. My shop thought the main bearings may not have been properly fitted. In another post it was mentioned that a similar problem was being blamed on vibrations from a slipped damper. Damage was also to the number 2 main bearing. See that thread at: http://www.y-blocksforever.com/forums/Topic63384-3-1.aspx Once I tore it down and found the problems I had the block remachined and bored to 292 specs (I had a set of new pistons on hand). Replaced the two heat damaged rods and then the whole assembly was balanced again to compensate for the change of pistons and rods. I hope to have it back in my 56 Vicky soon. Chuck
46yblock
Visits: 7.8K
Patience, Patience. Sounds like you have it. Better luck.
Posts: 3.0K,
Visits: 8.7K
Chuck, Mummert's got the timing cover tooling, he's workin' on it. I still have the water pump but I seriously doubt that I'll ever run more. It's complicated enough that I don't make anything on them.
stuey
Last Active: 8 Months Ago
Visits: 3.8K
Frank thanks for the offer but you can rest easy i'll not take you up. the stuff on the impeller was not weld spatter but some greenish glue loctite bearing fix maybe ?? seems tight but i only used my fingers thought i might break something if i used a pry bar/screwdriver Moonshadow thats a dream setup, i've never considered a blower and i think the insurance companies over here would frown stuey
Visits: 39.3K
You might get by with the McCullouch/Paxton unit as they were available from the Ford/Mercury dealers. Also, as I recall, it was the European market that did the early work on superchargers anyway? Chuck
46yblock
Visits: 7.8K
Picked up my pistons today. This is a 4 cc dome. Piston, pin and locks weigh 642 grams. Seems darn light for a 3.86 piston!
stuey
Visits: 3.8K
Mike they look great... i think i've a fetish for newly machined parts!! have fun with the spirolocs stuey
Posts: 3.0K,
Visits: 8.7K
stuey (9/15/2011)
Frank thanks for the offer but you can rest easy i'll not take you up. the stuff on the impeller was not weld spatter but some greenish glue loctite bearing fix maybe ?? seems tight but i only used my fingers thought i might break something if i used a pry bar/screwdriver stuey Stu, OK, but the offer stands. You were one of my very first customers. I won't forget.
