Main Support Girdles for the Y.
Posted By Ted 15 Years Ago
Posted 15 Years Ago
Last Active: 11 hours ago
Posts: 7.5K, Visits: 205.9K
In catching up with the slew of threads that were posted while I was galavanting at the Y-Block Shootout, I came across the girdle requests in Seppo’s roadster thread.  Due to the interest that’s being generated, I’ll make a new post out of this.
Hollow Head 9/1/2011
Ted, do you happen to have any girdles to sell or is it possible to make more of those. You sure have the drawings and it might be even cheaper to buy from you than discover the wheel again and manufacture those here in Finland
aussiebill 9/1/2011
Ted, I’d be interested in 1 if anything comes of seppo’s inquirey.  regards bill.
57FordPU 9/1/2011
Ted, I would also like to piggy back on these requests for a girdle.  If we are going to step up the speed on these Y-Blocks (especially turbocharged), we need to do everything possible to hold them together for a WOT three mile ride.
Although I hadn’t given much thought up until now to making any additional girdles for Y engines other than what I need for the current crop of in-house builds, I’ll put it on the list for this winter when things slow down just a bit.  The question comes up if the girdles (for those that are installing them yourselves) need to be pre-drilled and/or if studs/hardware needs to be supplied.  I see no problem in supplying girdles in either a pre-drilled or a non-drilled (blank) format.  Supplying the hardware gets more complicated but is expected to be doable if necessary.  The last crop of girdles I fabricated were for conventional timing covers and not the shortened marine covers.
I’ll add that using studs at the rear main typically requires an oil pan modification.  I’ve been both ways on the rear main attachment in regards to using studs through the girdle at that point versus using bolts under the girdle and not studding the girdle at that point.  Your thoughts regarding predrilled girdles, hardware, or anything else are welcome.  Another point is that the main cap tops around the bolt holes do require some milling in order to adjust the height of the girdle appropriately.
mctim64
Posted 15 Years Ago
Posts: 2.4K, Visits: 5.0K
Ted, I too am interested in the girdle. If you don't want to manufacture the pieces, a drawing with all dimensions would be fine as I have a guy here that could cut one or two out. (for Charlie and myself)
Posted 15 Years Ago
I'm interested, predrilled or as a kit.
Hollow Head
Posted 15 Years Ago
Posts: 1.0K, Visits: 3.8K
Atleast two pieces predrilled for conventional timing cover for us. Long enough main studs are also welcome, because atleast here it's bit hard to find inch size bolts etc.  Or those have to be ordered from somewhere Cool.
And Ted, congrats about joining in the 8's club Wink. We are far behind, but...
Y-Block Stan
Posted 15 Years Ago
Hitting on all eight cylinders (21 reputation)Hitting on all eight cylinders (21 reputation)Hitting on all eight cylinders (21 reputation)Hitting on all eight cylinders (21 reputation)Hitting on all eight cylinders (21 reputation)Hitting on all eight cylinders (21 reputation)Hitting on all eight cylinders (21 reputation)Hitting on all eight cylinders (21 reputation)Hitting on all eight cylinders (21 reputation)
Last Active: 15 Years Ago
Posts: 21, Visits: 112
Hi Ted, I also might be interested in a main girdle. I aquired a freshly rebuilt,stripped and polished 4-71 blower monday so I might try putting a Y block blower bullet together if I can find the time and $$$$. Thanks, Stan
ScottY
Posted 15 Years Ago
Normally aspirated (40 reputation)Normally aspirated (40 reputation)Normally aspirated (40 reputation)Normally aspirated (40 reputation)Normally aspirated (40 reputation)Normally aspirated (40 reputation)Normally aspirated (40 reputation)Normally aspirated (40 reputation)Normally aspirated (40 reputation)
Posts: 31, Visits: 204
G'Day Ted,
           I too would be up for a girdle or two also, at any level, though a stud kit, drilled etc would be a definate plus, thanks and congrats on all your work/efforts,
                                                  ScottY!
"MY TWO BOBS WORTH!" (Twenty Cents AUD)
Y-BLOCKS ROCK!!!!!
Posted 15 Years Ago
Last Active: 5 hours ago
Posts: 4.6K, Visits: 38.8K
Ted, Chuck Girdle? ChuckHehe
mr4speedford
Posted 15 Years Ago
Supercharged (87 reputation)Supercharged (87 reputation)Supercharged (87 reputation)Supercharged (87 reputation)Supercharged (87 reputation)Supercharged (87 reputation)Supercharged (87 reputation)Supercharged (87 reputation)Supercharged (87 reputation)
Posts: 82, Visits: 923
I'll buy one. Studs are not needed but pre-drilled would be nice. Please let us know when we can purchase. Very interested in a electric water pump if your still doing those as well. Thanks, -Andrew
1959 and 1960 f-100sAkron OH
RumbleFish
Posted 15 Years Ago
Turbocharged (70 reputation)Turbocharged (70 reputation)Turbocharged (70 reputation)Turbocharged (70 reputation)Turbocharged (70 reputation)Turbocharged (70 reputation)Turbocharged (70 reputation)Turbocharged (70 reputation)Turbocharged (70 reputation)
Posts: 70, Visits: 1.3K
Put me down for a KitBigGrin
Posted 15 Years Ago
MoonShadow (9/8/2011)
Ted, Chuck Girdle?
Chuck.  Your soon to be completed engine is using the girdle that was supplied with it.  Are you also requesting another girdle?
